New layout to the forum
783 views 1 reply 2 participants last post by  Smiley
#1 · (Edited)
This forum was since the first 2007 Versy, just that, then along came the V1000, heard rumors , could it be, BAM next thing we got V1000 joining the forum in droves, a sub forum was introduced, never was fond of that approach,then came along the X300, what has been done is produce 3 separate forums with the same basic layout as the 650, this allows you to search a topic in the sub forum, instead of getting searches from all the forums. More to come and something like a construction site, it takes time, should all be in place and complete shortly.
So enjoy.
FYI 5 pages of posts have been moved to the new 650 General discussions. Mass moving of the entire forum will be left to KawiMan
#2 · (Edited)
Thanks for your efforts to improve the forum- I know that mods do a lot of work to keep forums moving like a well maintained Versys.
Also, big thanks for the install of the Thermo Bob on my V. With the cooler weather coming I can be confident that the engine is running at the correct temperature.
I'm glad that I decided to take my time cleaning the filthy exposed innards before replacing the plastic, as I discovered a broken bolt on the left side upper engine mounting plate.:surprise:
The end of the bolt was protruding out the rear of the plate, so I applied some Liquid Wrench and simply screwed it clockwise using needle nose vice-grips until it came out. I found a spare 8x20 flanged bolt in my supply cabinet last night and will install it today. I will need to loosen the large bolt that screws into the engine and the upper plate mounting bolt in order to properly align the three holes, and then re-torque the fasteners. I used blue Loctite on the bolts.
The DPO (dreaded previous owner) had cobbled a set of highway pegs using the mounting bracket as a base. I suspect that the longer bolts he used were of inadequate hardness and caused the failure. I removed the pegs when I first purchased the V as they were too high and not useful at all.
