Front Fork Preload adjustment
9.3K views 6 replies 5 participants last post by  Nytrydr
#1 ·
I was trying to set up my front suspension according to the Cycle World article. On both preload adjustments I tried to turn the adjusters all the way in to get a starting point. Problem is the both just keep turing and neither will bottom out. I am assuming the lefty - righty principle is in place. Now I have no clue ifthe left and right forks have the same preload. Has anyone else had this issue? Please help.....
:confused:
#2 ·
All set. I never check this preload when I purchased the bike. From what I can tell both forks were full soft. I had to crank the preload for what seemed to be for ever. It seemed to be way more than 15 turns out from full in (hard).
#7 · (Edited)
Not much help there it just say's Jim took 2 turns off the preload on the forks. You need to set the sag for your weight. Front and Rear. I just had my sag readjusted be LE, my rebound settings stayed the same. all the way in on the fork and about 5 clicks in on the shock. the ride is much better.
I adjusted the sag when my bike was new and it made a big difference in the ride.:thumb:
Steve from Lindemann Engineering making adjustments to my suspension at La Ducati Day in La Honda on Sunday. I was really hoping to see Jim Lindemann there but Steve told me that Jim had another surgery for his brain tumors about 5 days before and was not up to making it. Ive know Jim from about 1978 back when he worked at Moto-X Fox and I worked down the street at Proto Pipe Exhaust Systems in Campbell CA.
Donn
see this post. http://www.kawasakiversys.com/forums/showthread.php?t=12355
