Booster Plug
FYI initially I deleted this post as the information was sent to me in a PM from a question I asked, so technically this is proprietary info from Steve in Sunny FL, he has given me the go ahead to restore this post, post 111
______________________________________________________________________________________________________________________________________________________________________
I thought I would share this, as some days I come up with ideas, then never get back to explore further. One such idea was contained in this thread,
https://www.kawasakiversys.com/foru...tions-performance-v-650/204313-boosterplug-opinions.html?highlight=booster+plug
I never followed through as I knew the contents of this thread with a
new Flash was in works, plus I waited so long to ride the bike into late June 2018, I decided against screwing with it.
So I decided to contact someone with far more knowledge into this aspect than I have, basically not a I think but
I know , yes I am referring to Steve, so I thought I would share his reply, basically confirms what I suspected all along, but with far more detail.I am also copying this post to Boosterplug thread.
This was my question:
My question is the intake air temperature directly related to fuel mixture & timing, as that is what it seems as to booster plugs. Since I knew your flash was in the works I never bothered to try adding a resistor to change air temp reading input ( discussed later on in that thread under experiment here I come).
And his answer:
Yes, there's an ambient condition sensor that will richen the fuel as needed with outside cooler temps. That's what the booster plug is doing. the problem is that there is a weird fueling strategy in the ecu that has both cylinders operating with different fuel charts, and they switch, where one is richer and the other leaner for a couple thousand rpm, and then they reverse. There are areas where I've taken considerable fuel out... so in that area the booster plug would be adding fuel... not a strategy I think is viable.
