Here are a couple pics of my new Zeta hand guards on my 2011 Versys...Install was easy except I had to loosen the banjo bolt on the brake line and swing it up a bit...as shown in on of the pic's below....
this picture shows brake line I had to rotate....
I used the stock bar end bolts instead of the ones that came with it...my bars are filled with 7 1/2 lead shot so losing the bar ends doesn't affect anything....But in the future I am going to pull them back off and rattle can black the space in between the bars and the backbone piece...or get my friend to machine down the stock bar ends into spacers...
oh and btw they don't hit the Givi screen even at full lock
any questions feel free to contact me
Dan
Mine are Zetas too. Looks like this is the only way to install it -- minus the bar-ends :)
Funny enough but I've kinda got used to the vibes without them.
I noticed that other seem to have different backbones than mine the do a curvy thing at the bar ends..I order the straights cause I was following Webbike Worlds install any reason besides looks that one works better than the other...
Dan
Dan
It's to add clearance for the levers. Most people don't install bush guards/bark busters correctly and many times end up cutting the ball-ends off the levers to achieve clearance. Other than that, the bendy ones are just different and obviously some folks like the look.
update with pictures
Ok the bar ends I order came in so I thought I post the newer pictures
If u look closely u can see I moved the control perches out to get rid of the gap seen in this picture
the bar end are so light I doubt they do anything but act as a spacer but it was need to get the look right and allow me to clean up the ugly gap
YMMV
Dan
Zeta hand guards fitted on my bike, with the original bar end weights.
rgs
:yeahsmile:
YMMV
Dan
