1 - 3 of 3 Posts
This was a pretty common mod on my Aprilia Futura, made a HUGE difference in available volts for farkles. Not sure if the V needs it, never took measurements.
Put a voltmeter on the headlight bulb terminals when the headlights are ON. If it is much less than battery voltage put relays with thick wires with big in-line fuses wired back to the battery to feed the lights without going through all the switches, fuses, dip-switch and wiring connectors..
On my Yamaha xtz the voltage at the bulbs was 8.5V. When I put the relays in and got 13+ V at the bulbs they were like searchlights.
Don't forget to put 2 fuses in, one for main and one for dip beam
I havent checked the Versys as I avoid night riding. I MUST do it.
Ted.
1 - 3 of 3 Posts
