1 - 3 of 3 Posts
If there's a more appropriate place to post this, I looked but could not find it (sorry if not in correct forum!).
I've been trying to PM another member. After receiving no response, I look to find 0 messages in my outbox. I try again, and get the same thing. I try to PM Admin to help troubleshoot, same thing (not showing in outbox).
I tried from home laptop and from iPhone- same result.
Mods/Admin, please help!
Thanks in advance!
Byron
PS- To shed more light... I'm not a noob, I know how to send a PM. It's a technical issue. :)
When you send a PM you will see down below under additional options, Miscellaneous options and if you select Save a copy of this message in your Sent Items folder. I think default setting is not to save your outgoing PM's
Phil
Phil,
You are correct. I see the option and it was not set to save the message. I just sent you a PM to test, and it appears in my outbox after checking the box you refer to. I learned something!
I assume the previous messages were sent, they just didn't show up as sent (from my outbox/mailbox). I thought it had something to do with the fact that I've been dormant on this site for a while, but apparently not.
Thank you!!
Byron
1 - 3 of 3 Posts
