As you can see in the picture from "Time", there are 2 metal vents on the bottom left side of the tank. There should be one that has a tube on it now so your loose tube should fit on the other one. Each tube has a clip that holds it on so make sure yours has one. They can sometimes be a pain to attach properly. You have to unbolt the tank base and raise it to have room to work. Be careful with your gas line connection. Good luck!
...You have to unbolt the tank base and raise it to have room to work. Be careful with your gas line connection. Good luck!...
You SHOULD be able to put a piece of 2x4 under the base (where the two bolts go thru) standing the 3.5" side UP, giving ENOUGH room.
