1 - 20 of 29 Posts
Hello,
I currently have 11K miles on my 08 Versys and I am starting to wonder when I should change out my tires. I bought the V late last summer with a little over 10K miles, so I haven't put that many miles on the bike. I have no idea if the Dunlop Sportmax tires are the original OEM tires, or OEM replacements. The tires look in pretty good shape, but I don't really know what worn out motorcycle tires look like.
I am fairly easy on the bike, so I would think tires would last me a while. I have seen thread where riders are only getting 4-6K miles on their tires before needing to replace them again. Again, I have no idea if these are replacement tires, or original OEM tires.
How do I know when it is time to replace the tires? Also, how many miles should I expect to get out of motorcycle tires? I understand different types of tires get different mileage, but I was thinking of what type to buy when I do replace them.
I was thinking of the Avon Distanzia 90% street 10% dirt or the Michelin Pilot Road 3. I don't really do any dirt riding, but think the Avon would be a good balance.
Any help would be appreciated.
Thanks Everyone
Jason
Hello,
Thanks Everyone
Jason
The Dunlop sportmax are the original tires that come with the v stock. Michelin pilot road 3 are great replacements from what I have read especially if you plan on riding in wet weather
You inspect your tires for damage and you measure your tread depth. There are also wear bars on the tires just like on car tires. The Owners manual tells you how much tread depth you can have. I think it is something like 3mm front and 1mm rear.
You can never change a tire too soon, but you can change one too late. ;)
I just read the manual and it suggests:
Min Thread depth.
Front: 1mm
Rear: 2mm if below 130kph and 3mm if traveling faster
The Stock Dunlop sportmax aren't the best tires, a real lousy performer in the wet. My tires are reaching 10k km, and the front is at its final life while the rear still has another 3k or so km. With the shallower threads, I am lowering my pressure on the tires in order to get more grip, and it's not bad actually. It would mean more wear but I just can't wait to wear it out so that I can install some good rubbers. (Pirelli Scorpion Trails or Michelin PR3)
I have 13,000 kms on the stock Dunlops. They still have live in them, but I have a plug in the rear (since about 11,000 kms) and I bashed my front rim last season, so I'm replacing the set when I mount the new rim. Just bought Michelin Polit Road3s.
If not for the damage, I'd likely run the rear to about 15,000kms and the front maybe even longer.
The Michelin PR3's have been great for me.
The stock Dunlops, leave the pressure as stated, 32F, 36R psi. going higher will impair you from having fun. Had a blast yesterday as I went into the twisties en route to home, grip was good in turns, and lean more. Even the wet grip was a lot better.
2damax....You talking about the stock Dunlop Sportmax. I am now 6700km usage and the wear on the front is really showing. I pump 33/36.
And this tyres are bad in the wet.
2damax...How much is the Pirelli Scorpions ( 1 pair ). Thanks... :)
Just changed the front BT016 to BT 023 on my z1000 with 7400km as tyre was cupped and had some bad ridges on it which you could feel if you pushed bike in corner, could of made it last another 1000km if i wanted to wear tread out but was not confident in it.
I always wait way to long . And after I do change them out I swear to myself I will never wait that long again .The bike just rides and handles so much better with new not worn out tires . But as usual I waited to long on my last front tire change . But after I changed out the front tire I did promise myself that I would not wait that long again .lol
Discussion Starter #18
I don't consider myself dumb about motorcycle tires, just a little less educated than many other members on here. I figured I would ask the question given the wealth of knowledge I have seen on this forum. I guess I could have looked in the owners manual; however I know what is written in the manual isn't always the same as the real "ground" truth out on the streets. I am still fairly new to the world of motorcycles and I am just trying to soak up as much knowledge as I can.
Thanks for all the great input everyone
I replaced the stockers at around 6500 miles (10Mm). Rear tire was squared off bad with minimal tread depth in the center 2 inches (past the wear bars) and plenty of tread on the sides. Bike would fall off the edge pretty distinctly in the corners and rear was drifting on acceleration. The front was still pretty good. Should have swapped much sooner, but I was still comfortable riding it.
I still got the old ones in the shed if you want a picture.
1 - 20 of 29 Posts
