Can you just loosen the assembly and retorque, shifting it over? Or do you have to pry it over about an 1/8" with something long, skinny, and strong? Putting it in a vice would suck lemons for 1/8" bend.
:thanx:
Thanks Maverick, but MotoHelmets readjusted my bars for free and fixed it for me :)
HB bars rule, and paid their way 5 hours after being put on. I've had them on a Honda 750 Nighthawk and multiple BMW's. They will always be my number one choice in crash bars. And usually a puff or two of Walmart black spraypaint fixes them back to life, even if they are chromed.
I Needa get me a set of the crashbars for my 650, sounds like your's worked out just perfectly. Although I don't plan to ride in such a way that it would require protection, you know how that goes, it wouldn't be fun either!
I wedged in a piece of rubber between the HB crash bars and the plastic that was rubbing. Stopped the vibration, and was an easy fix.
I'm happy with my SW-Motech bars
I did get the SW rear AL rack, and liked it until I put my Seahorse 720 top case on last night. There was no room for screws on the outside, and four 1/4" screws on the inside pattern was not too secure. I'll see how the wind does with the 11 lb capacity rack today. I may have to add screws to it; but with windshields, I found the optimum number of screw secure points were 4 from trial and error.
Hopefully, it will be all right. Now I know what a member meant when he said the box was wobbly with a Rotopax on top. I may have to downsize from the preferred 1.75 gallon can to the 1 gallon can because that will be the max weight of my (or any) top case rack (resting on a narrow width AND 5/8th the case length.
Note, I should have gotten a larger rack :-( It's light anyway.
