1 - 4 of 4 Posts
Trying to buy a used set from a member. The U bolts are missing from his posted pic. But, i think another special spacer #12 from pdf is also missing.
PDF manual :: http://static.twisted-throttle.net/media/files/sbl.08.508.100.rev01.installation.instructions.pdf
Member selling crash bars hardware pic ::
Another member performing an install hardware list pic ::
Looks like, i should be able to source the U bolts from the local h/w store. But, what about that other spacer? [the half cylinder shaped one]?
the flat sided spacer goes under the left foot peg on the extra long bolt... That is pretty important.
Looks like you're missing some nuts, which you can deduce based on the photos. You have the 4 for the u bolts, but only one left. There should be 2 matching ones for the front most mounting points (those 2 shorter bolts) and one for the long bolt (the biggest nut of the set.)
Also, there's black plastic rings for the frame to protect it where you tighten the u bolts..
I would maybe not buy that kit?
(I just installed mine 3 hours ago)
I guess i can buy the nuts from a local store, but that special spacer would be tough to find.
1 - 4 of 4 Posts
