1 - 4 of 4 Posts
What are these electrical connections for? In attached pic there is a 6 pin connector (upper right), clear plastic connector, & taped up wires down the left side.
I cant see your image clearly, but will try and answer your Q, The 4 pin connector on the upper right is for dignostics and the blundle of wire are from the ECU which is just below the seat lock area. some of the wire are for back lights and the others run to the fuse box just after your tool box area. Hope this helps otherwise refer to the wiring diagram.
Fastoman:cheers:
1 - 4 of 4 Posts
