1 - 14 of 14 Posts
Not able to start my Kawasaki versys 650 2014. It was running fine and then after completing a long trip it died.
Current state:
It would something idle for sec and then die if I open up throttle it would go for a bit and then die.
Video:
Info:
It has 20k miles but it was starting and running without issues.
Things checked:
So far I replaced sparkplugs and air filter which looked dirty. Battery is fully charged and gas is full.
Did diagnostics but did not see any code messages.
Discussion Starter #2
Not able to start my motorcycle. It was running fine and then died.
It would something idel for sec and then die if I open up throttle it would go for a bit and then die.
Video:
It would something idel for a sec and then die if I open up throttle it would go for a bit and then die.
Video:
photos.app.goo.gl
New video by Zilvin
So far I replaced sparkplugs and air filters which looked dirty. The battery is fully charged and gas is full.
could be the vehicle-down-sensor (VDS)
this thread mention a hack just in case you want to assert if that is the actual trouble:
you need to learn to use the editor and embed images and video.
otherwise you just look like your are posting phishing/scam urls...
Hi Zilvinas, why don't you share model year so we have more information? Carburetor, fuel injected?? Little more info could help diagnose.
Is your IAP sensor hose split/cracked or detached from left TB vacuum fitting or IAP sensor near left turn signal? Make sure all is as it should.
Administrator
FYI I received a PM / Conversation, whatever you want to call it from the OP his comments in blue
I was reading your comments and I was very impressed with how much knowledge you possess. Currently, I am in a pickle by being on a road 1000 miles away from home with a bike that would not start.
Could you take a look and let me know what you think?
comments earlier by Invader were pretty accurate, you have a 2014, unless you were in some heavy rain for several days I don't see the vehicle down sensor. First thing is I need to tell you I am quitting this forum, my dog just got sprayed by a skunk , my house smells like skunk and we just did the baking soda / hydrogen peroxide thing. There is a work around for the tip over switch, but I wouldn't be riding 1000 miles bypassing it. My first guess is the lines Invader said, I would go to a auto parts store and get some 5/32 vacuum line about 3 feet, replace everything, pay attention to the lengths on the throttle bodies, you can make them 3 to 6 inches longer than stock , just make them the same/ equal length. After that you need a digital meter to solve anything further. see post 25 , you need a 12,000 ohm and 3000 ohm resistor, or variations of that. I could explain further but the vacuum lines are my first place to change Vehicle Down Sensor / Tip Over Switch / Bike fell down...
I will check back tomorrow.
Next and this is simple, unplug the main and subthrottle sensor connectors and if you have a small amount of dielectric grease before you plug it back in, ( less is better)the grease helps to seal it and improves conduction.After that you need a meter. My second guess is the connector on the right side of the air box may not be plugged in correctly.
It seems that the tip over sensor connection was an issue. When I disconnected the male/female connector I noticed a lot of white gunk.
Last night I was cleaning it with electric connection cleaner spray. I am hoping that it is just the connection not the inner housing of the sensor.
Keep you guys posted.
Administrator
First look at the time of post#11, yes in a new thread, I didn't see it until a hour later, so moved it here at 10;12 AM
Got this from the OP a few minutes ago , his text in red
I disconnected VDS switch and opened a can of warms--the connection was full of white gunk. When I unplugged it, the moto would start and run without a problem for 5 sec then it would die--which is a good indication that it was an issue.
I was cleaning the connection with electric connection cleaner spray with a hope that the issue was only with the connector by not the sensor housing itself.
I am hoping that there are no more problems.
The rectangular one is the California charcoal canister, the round one I'm not sure because I have a newer bike that doesn't have it.
Administrator
First , please keep all your posts within this thread, people that have responded before have a history of what is going on, posting in multiple forums just thins out the response. This is my last time I move things. :cool:
1 - 14 of 14 Posts
