1 - 20 of 21 Posts
I am wanting to change my shock spring out for a different spring. The Kaw shop wants $75 to change it. I thought that was a little steep. Any thoughts on what else I could do.
Thanks.
You'll need a bike jack and a spring compresser to do the job safely. You can use a bike jack for lots of work but a spring compresser is one of those once in a life time use tools unless you're a racer or shop. See if they'll give you a break if you take them the shock off the bike.
What I'd do is see how much the tools will cost and then decide if it worth it to buy the tools need to do the job once or to pay to have it done. A job I'll do over and over I'll spring for the tools, bought a Tusk Chain Rivet tool as I do chains more that once or twice. BUT paid the shop to do the oil chainge of the forks on my Buell as I knew it would cost a lot more to buy the tools to do it once.
My Advice: Rent a bearing removal tool and find a repair shop in your area with a hydraulic press. Does'nt take 10 minutes to remove 1 spring and install the other. Matter of fact most shops with the above noted press will HAVE the necessary bearing tool also.
Since I am a newbie, to this. I have another question.
How do I jack the bike up to take the pressure off the swing arm?
The normal "Lifters" are just to get the back end up say for to change the tire but still have pressure on the swingarm.
Help me if I am missing something, I want to pull the shock myself but am not sure how to go about it.
Thanks.
I have a motorcycle lift BUT I have not used on my Versys. The lift raises the bike from under the motor and on the Versys the muffler and header piper along with the lower fairing might be a problem, I don't know. Push comes to shove I'll pull the muffler off and use some 2x4s to make a spacer.
The lift I have came from Sears, I use it mainly on my KLR.
jack
Your link did not work but it got me to looking at Sears. I just ordered the Craftsman motorcycle jack for 90 bucks shipped thought that was a pretty good price.
Thanks
Lift the rear of the bike up using a good rear-wheel lift. Put a 12" high car jack under the foot pegs on each side. Remove the rear-wheel lift and the bike is supported with no weight on the rear wheel. Loosen the front shock bolt. To remove the bolt, you will need to lift the rear wheel just slightly. I do that by inserting a round point shovel under the rear wheel and lever it down to raise the wheel, while I'm unscrewing the bolt.
It's a little easier if some one helps you, but you can do it alone.
I suggest you return the Sears jack. Use the money toward a T-Rex rear stand. I'd also add a front stand too, if you're planning to do your own maintenance.
shock
Thanks.
Scottyneal. That description helped me picture the job in my head. Appreciate it.
Don't the spring loaded pegs want to flip up? Or do you put the stands under the peg bracket?
Thanks, one of my "To Dos" is to repack the swing-arm bearings and this will save me pulling the muffler and rigging a spacers to use the jack.
Greasing the swing-arm bearings while you've got the shock out will save you a little overall effort.
BTW, not sure why you're changing the shock spring, but suggest you consider HyperPro progressive springs. They have two for the Versys: one for lowering the bike 30mm and another stock height. Both are progressive and make a nice improvement in the ride. They also have progressive springs for the front (30mm lower and stock height) which improve the ride and greatly reduce the front "dive" when braking sharply.
I'm not changing the shock, only greasing the bearings. I do plan to upgrade the springs at least but a bit down the road thanks to a hospital stay.
Discussion Starter #16 (Edited)
I actually have a hyperpro spring in it now, one that lowers the bike by 30 mm, I need the bike as tall as possible since I am 6'2. I got used to my KLR height, and the Versys feels low the way that it was set up with low gel seat and this low spring. So far I have gotten the lowered pegs adapter from speedys, put a stock seat back on it, now to replace the spring with a stock spring, and I believe it will fit my riding style much better.
Took your advice.
Returned the Sears jack. Ordered a pair of Trex with free spools today. Instead of the fixed jack stands, I have some open rafters I plan on, once the rear end is up attaching the frame to the rafters to leave the swing arm free to work with.
I had a problem with the bike wanting to swing around when I tried to tie from above. Probably needed some ties to the side. That's why I finally used jacks under the foot pegs.
I suspect there are people here on the Forum that would trade you a stock spring and some money for the HyperPro lowering spring, if you want to raise it another 30mm. Or just sell your lowering spring and get a stock height HyperPro progressive spring - for the better ride.
Discussion Starter #19
When I got the bike it came with the additional stock spring, so I will probably just be selling the Hyperpro.
I thought about the swinging problem, so I am going to try to go over two rafters, and have clevises that I will attach to the chain directly underneath each rafter then run my rope from each side of the frame (underneath the seat) to the individual clevis, also may put a small eye bolt in the floor and attach the bottom to it.
Discussion Starter #20
So far so good on advice from ScottyNeal, on how to change out my shock on the V.
I used the jack stands in tight on the foot pegs. For added insurance I tied it off to the rafters too. Glad I tied it off to the rafters on the one side with a small come-along cause just with the jack stand height could not get the bottom bolt out, had to give a few clicks to the come-along to get the back bolt to clear the frame. The shock is now at the shop getting the springs changed out.
1 - 20 of 21 Posts
