1 - 3 of 3 Posts
Is any part of the Versys electrical system 5V, or is it all only 12V?
I wanted to have a thermometer on the V, so I bought a PC thermometer which unfortunately needs 5VDC input.
If needs be, I will use an LM7805 to regulate down from 12V to 5V, but I was hoping to just find a 5V source that I could tap into.
Is that an outside temperature PC thermometer? No 5 volts on the Versys. The ECU, and the O2 sensor (where applicable) runs on the battery's 12 volts...
easy enough to get a 5V power
buy a mobile phone car cable/MP3 player. but check the voltage and current. or buthcer an existing one for an old phone.
failing that find the current of the device and then buy a voltage regulator appropriate for the thermometer.some smoothing capacitors and knock one up.
1 - 3 of 3 Posts
