1 - 20 of 30 Posts
Hello friends,
I have a Versys-650 (2017), and recently did some work on the same. I have captured the activity in video, thought of sharing here.
1) Replacing the Coolant in Radiator :
2) Installing a Mobile USB Charger :
3) Chain Cleaning & Lubrication:
4) Moto Jack to lift rear wheel :
Temporarily Stuck
Once I have more time to view these, if the info is accurate I will copy these posts to the correct How To Forum threads.
thanks friends for the nice words, it encourages me.
Im learning each day, and some I try to capture in my start-up YT channel!
Btw, I already have the Easy Clutch adapter, on next opportunity will install it.
thanks for the videos. well done. i had a student a couple of years ago named pooja. nice kid. going to med school now.
Where can I find a jack like this?
Reactions: Mattias
Discussion Starter #15
You can find that moto-jack on Amazon.com or even Revzilla.com
if you are good in fabrication, can try making one, basic idea :
- get two "C" channel strips, one with 1.5in and other 2.0in width, both about 6-8in in length
- the thinner one slide a bit (1-1.5in) in the wider one, drill holes, and put a bolt across : makes a clamp like
- make a groove cut (if you want to mount on spool)
- on the base part (the wider strip), can put some rubber or a flat piece to get a good base support.
regards,
Pranav
Discussion Starter #17
Hi friends,
just documented another method of clutch cable lubrication - I would like to call it "oil-well" method :)
regards,
Pranav
Water drain hole on the right side.
Water drain hole on the swing-arm (V650 2015+):
For the right side, I've been thinking of making another drain hole closer to the axle similar to the one on the left side. However I keep holding off wondering why Kawasaki didn't do it the same as on the left side. There must/could be a valid reason for doing so.
My left side drain hole was plugged for a long time before I got around to it. This led to corrosion on the chain slack adjuster bolt which eventually seized up. I drilled out that hole a minuscule amount larger.
Discussion Starter #20
yes, it would be interesting to know the logic behind. or was that just a miss ?!!
oh yes, few of my colleagues faced the same issue. so now every few days, I just put my finger under the left hole to ensure its clear!
And I bet, a lot of people don't even know that such drain holes exist, or even it get clogged!! :)
1 - 20 of 30 Posts
