1 - 14 of 14 Posts
Using Swing-arm Stand on Lowered 650LT - difficult to raise & interference w/R Fender
Just lowered my 650LT with the Motowerks lowering kit and bumped in to a couple of side-effects that I have not seen in any of the discussions on the subject.
1. I've found that it makes putting the bike up on my Pitbull stand much harder.
2. To my dismay, when I remove the stand, I find that the stand hits the plastic fender flap that the license plate is attached to and twists it, thereby placing a lot of stress on the plastic itself as well as where it is mounted! (plastic piece HERE, part# 35019 and 019A).
Am I the only one who has noticed this (yes, I have searched for this)??
I had the same problem with a non-lowered 2007.
After I broke the rear reflector I removed the number plate, cut the plastic tail at a point it couldn't be seen, doubled up about 3" of the plastic, drilled and bolted it together and put the plate back on.
No one can see the difference, the reflector still points backwards, and the stand doesn't hit any more :)
Instead of bolts you could use pop-rivits or glue but I had some 4mm x 13mm / 1/2" long bolts and washers sitting around.
You can cut off the "tail" just below the license plate (what I did) or extend the arms on the stand (which I did also). No interference problem now.
The first thing I did when I got my LT last week was cut about six inches off the tail where it meet the license plate. Looks like it came that way from factory. Use a nice black license plate cover to finish the look off.
My Pitbull stand's arms do not extend.
I have the Harbor Freight stand and you can just unbolt the arms and move them about two inches. Re-drill one hole and it's extended. Pitbull stand must be different. Trimming the tail off just below the license plate is enough to do the trick though.
Excellent.
Where did you get the license plate frame? Dealers around here (Houston) used to give them to you for free if you were a regular customer but they don't anymore.
OK, so we've talked about one of the two problems with trying to put a lowered Gen 3 Versys up on a rear stand... the interference of the rear fender while trying to raise or lower the back end. The other problem is the greater physical effort required to get the bike up on the stand because it has been lowered.
My stand is a Pit Bull stand and the arms to which the spool forks are attached are not adjustable to make them shorter, so I need a stand with shorter arms. Anybody use a stand right now on a lowered gen 3 Versys that works well and has shorter arms? If so, what brand and do you have.
I don't see why a lowering kit would make any difference - the spools are attached to the swing arm which is not affected by the lowering kit.
Lowered/ Waiting For a Response
Yes, I was puzzled by the question about more difficulty on raising a lowered bike. My 07 was lowered and my 2015 is lowered, the distance is identical from the ground to the spools. A couple pointers, I looked at a pitbull stand that Kawdog had, which lifts from the front of the wheel,that was something I considered making and would be possible to use your foot to raise the bike, however, price was $200 plus, almost the cost of my 1000 LB hydraulic lift.
Second thing is the mod Eddie did, I installed Givi Trekker side cases and a E56 top case, part of the install is relocating the signal lights, this involves taking the tail section apart, including a screw right by the reflector. You pop rivet it together, only one way it is coming back apart.Yes I have the same stand everyone else has, I extended the handle using 1 1/2 square aluminum tubing. Generally I use my prop stand 80% of the time and my Harbor freight stand 20% . The advantage of the Harbor Freight is that I don't need to take off both side cases to lube the chain like I do using the prop stand, however I don't like the fact the whole rear end is in the air, several times I have had the aluminum POS flex and it came close to going over, just remember where you are in relation to the bike. The prop stand is 100%, unless the side stand fails , and that is why I use it 80% of the time.
Here is a link to my stand and the pitbull, my stand is the same as post 17, the pitbull is post 33 and 34
http://www.kawasakiversys.com/forums/74-how-forum/121554-stands-pit-stands-jacking-other-methods.html
Don't know. All I can tell you is that using the same stand, I could get the bike up just fine using my arm on my '09 Versys, but on the one time I raised the lowered '16 LT, I had to use my leg to press the stand down. Maybe it had to do with the rear fender/reflector getting temporarily hung up on the stand?? If that's the case, it should lift just fine once I've bobbed the fender.
I have noticed that on mine also. IMHO it's because the center of gravity of the whole bike (weight in front of the swingarm) has been lowered. It therefore takes more effort to raise the bike.
That's my story and I'm sticking to it. :D
1 - 14 of 14 Posts
