1 - 2 of 2 Posts
Hood Product Green Automotive tire Motor vehicle
About two months ago, both my rear turn signals fell off my 2017 VX300 (9500 miles, mostly pavement). Two day ago, my left front turn signal fell off.
Carbon Automotive exterior Composite material Bumper Hand tool
The turn signals are supported in the bodywork by expanding the rubber at the base of the stalk with what Kawasaki calls a washer and nut. The washer/nut expand the rubber portion so that it cannot pass through the mounting hole. The tension on the wiring harness is what holds the turn signal assembly in place.
Apparently the vibration of the bike causes the bodywork to wear on the rubber ultimately causing it to fail. Repair consists of replacing the entire turn signal assembly (about $50+ USD each).
Anyone else had this issue? Interestingly enough, I also have a V650 (2014 model) that uses the same system that has had no problems. Did Kawasaki get some different materials?
I have had to replace all four turn signals on my 2009 Versys 650, the rubber neck/boot breaks down with age and tears. Aftermarket turn signals are easy to find online. I just replaced the two front turn signals on my bike yesterday. The replacements came via SpeedPak from China in about a week.They had bullet connectors and of course the original Kawasaki ones have proprietary connectors, so I just took the rubber parts from the new signals and switched them out onto the old lights, which were in perfect shape otherwise. I now have two spare turn signals - sans the rubber boots - which can always be installed by either soldering or crimping the wires along with some heat shrink tubing. Cost - $20 including shipping. I am surprised that they have failed already on your 2017.
1 - 2 of 2 Posts
