1 - 20 of 34 Posts
I've searched for, but haven't found, information on running lights. I'd like my turn indicators to function as running lights to increase my visibility. Is it possible, and if so, how is it done?
Basically your front signals are currently a 2-wire system.
You need to convert it to a 3-wire system.
Where you get the power for the "always hot" line is up to you.
You will have to change out the bulb socket to a bulb socket made for dual-filaments. Again, the stock one is a single filament.
I did this with the rear lights on a Suzuki C50......the fronts were already running lights. It is a PITA and I couldn't find any plug and play stuff. I had to manufacture everything. Did I mention it was a PITA?
I bought a pair of "Bullet lights" from somebody in England (around $20, near as I remember), and set them up to be ON w/ the key to ignition. Here's a couple of pics.
Thanks for the good tips. I don't have any experience with wiring. Plug n play is more my speed.
Kisan may make something; I think its Signalminder has an option to convert to running lights. Custom Dynamics sells a lot of different lighting products; could have something. I'm certain Signal Dynamics has something -- they make lots of that kind of stuff.
Those look good fasteddie! Do they put any extra light on the road, or just strictly to help you be seen? I'd like something that adds a little more light at a wide angle -- to better see into curves and watch for deer on the roadside.
Well, this is a bit of a hijack of the original thread subject.
These are a pair of 10w LED lights from superbrightleds.com. They offer this one with with a choice of 10, 30, 60 or 102 degree beam angle. They were about $35 each. I got one 10 and one 30 degree.
Superbrightleds has wiring harnesses as well but they are made for cars so they have panel mount switches and about a mile of wire. Go to Harbor freight and get some wire, connectors and heat-shrink and it should be pretty easy to make your own sub-harness.
Twisted throttle has light bars to mount driving lights to different versions of the Versys as well as some generic mounts to mount to forks or other points. The light bar for my Versys 1000 was about $75, iirc.
The V1k is wired for accessory lights so no relay is required. You just need to build a sub-harness and find a decent handlebar switch. The switch I got from Amazon for $18 is a piece of junk so I won't recommend it. I just ordered a new one from Touratech but it's stupid expensive at about $45. Whatever, I guess you get what you pay for.
The lights seem to be nicely built. They are very solid and come with stainless steel hardware and waterproof plugs to build your harness with.
Kawasaki offers a driving light kit for the big Versys for a bit over $500. I put this setup together for around $200 including buying two switches. These two pictures (if I got the links right) show the low and high beam against my garage with no LEDs.
The lights definitely fill in around the regular headlights and the color is very white. They make the stock lights look very yellow. I'm still messing with the aim of the lights to see if I can run them without getting people flashing their brights at me. I don't know how much that really bugs me though since every other car is running driving lights and every third car is running with high beams in traffic here.
I installed the lights from superbright that Forrest shows in his post. I used the harness from superbright also. Installed the switch in the dash panel. They work great and I have them aimed out to the sides just slightly and they are paying dividends spotting deer in the am on the way to work. I just need to wire the trigger for the relay to a hot source only on at ignition vs hot from battery like now. As far as running lights, I bought 4 of the small amber pods from superbright and mounted a pair on the sides of the body work at the tail. I'm going to put the other 2 in a location that won't be covered up when I throw on bags. I wired those into the parking (city) light circuit in the tail (cable for the plate light). I need to take some pics of the running lights but they give a nice glow out to the side. Those strips mounted on the hand guard shells are an eye catcher for sure...nice job!
STRICTLY to be seen.
I HAVE a pair of Denali DM spots to go onto my Gen 3 when I get back to BC next April. I'll use wide on the right, spot on the left.
Looks great, what size did you use? 6, 8, or 10 LED?
Can you post a picture in the daytime? Thats when we really need the extra visibility.
I used the smallest one's available (6 LED), will post a daylight picture in the morning :)
If i used anything bigger it would wrap around the handguard, didn't want that since you're looking into the leds when driving, would have been to distracting.
https://nl.aliexpress.com/item/Newest-car-styling-High-Power-2pcs-6-LED-daytime-running-lights-DRL-Flexible-Strip-Eagle-Eye/32319379900.html?spm=2114.13010608.0.0.5bZiQZ
I have been riding around for 4 days with the lights and i really have the feeling it helps being more visible, we had some bad weather recently and filtering traffic has been easier, cars pull to the side way more then before i had the lights. Not sure if it's just wishfull thinking but it really seems to help day and night.
Took a while, sorry. But as promised a picture of the lights in daytime.
Kinda hard to capture with a camera though.
Close up Pictures
Here's the electrical guy asking if you could post some close up pictures of the mounting and wiring. I can see where if possible it would make even more visibility if yellow were also available, you could then add those above and tie into your turn signal.
One observation I have made is, the distance between the Barkbuster , gives a much wider field of view for a car driver, the height is about equal to the top of a hood of a car, a quick glance by a car driver would definitely be more visible than without the light strips.
:thumb::thumb:
Looks like I am going to have a really busy winter, only problem is we keep getting warm spells, next week looks like another ride day, low of 5'C and high of 8'C with plenty of sunshine, on Tuesday.
:rolleyes:
1 - 20 of 34 Posts
