1 - 20 of 26 Posts
Seems the stock spacer inside the shock that incerts into the lowering link is widwr than the lowering link. Anyone have this issue? We've been grinding it to try and fit it but it's getting shorter than the shock. Might not be a good idea to do that. Any thought?
pictures would be nice
What brand is the lowering link? Motowerks should fit perfectly.
Suggest you give them (Speedy) a call, or send email. He's very responsive.
l've never heard of a problem. I installed two of them on my 09V and 10V.
I measured 1.256" between the faces of the lowering block - where the shock attaches.
Yours must be less than that. If so, you need a replacement; from Motoworks.
Thanks, friends. I did contact them this evening. Have not heard back yet. I need to start remembering to take pics when things are not going so smooth. I am not used to doing the work myself.
Sorry, but What do you mean I need a replacement? Thanks.
Beth
I just installed my lowering link last week.
I put it together, and it didn't look right. I noticed an extra washer laying around. I then rechecked the instructions. I found that I left out the big washer that is to be used under the nut. Once I put that in, everything snugged up perfectly. It works better than I imagined. I also installed a new shock from Progressive. I feel much racyer with a lower bike!
Did you follow the instructions? Mine went perfectly and the only others that I have heard about going wrong didn't follow the instructions.
You're almost there! You better be thinking about the adjustable machined side stand NOW. Don't forget how heavy it is! Raising and lowering bikes are usually hell.
Sorry friends. I forgot I posted this post! No luck still. The part that is holding me up is the sleeve inside the end of the shock absorber that fits into the lowering link. It's too wide/long! The link is for an ABS bike but the company and the seller says it will work on my non-abs bike. Not getting a ton of help from the company. I am trying to talk to speedy but can't get past the woman in charge of ordering. I tried to call him again today. We tried filing the sleeve down but we are concerned about modifying that part too much. Sorry no pics, have not tried an install a second time yet. Does anyone know what I am talking about?
Beth
Beth
Pics, Baby, pics: we need more pics!
Pictures should be worth a thousand words. This is Motowerks Abs model because I have a rear hugger. Fits exactly the same as standard model.
Yours should be just like this. No grinding necessary.
ImageUploadedByMO Free1431730185.787602.jpg ImageUploadedByMO Free1431730201.625994.jpg ImageUploadedByMO Free1431730227.875742.jpg ImageUploadedByMO Free1431730252.570769.jpg
This problem seems strange. The space in the lowering link for shock is same as factory shock mount. The person installing this is not trying to include the washer in the spot, are they? heres the link to the instructions. I had no trouble installing mine. To verify the problem, raise bike by foot pegs to remove load from spring, disconnect the shock from the swing arm mount point. lift the rear of shock and put it in the lowering link. The lowering link at this time should not be connected to the bike. Motowerks has a good product, with good instructions. The only way it would not fit, is if someone had installed the incorrect shock and made changes to the factory mount point to widen it. To check that out, use the hollow spacer rod in the kit. Fit this into the factory shock mount point. It should be touching the 2 sides. If it wiggles excessively, someone made changes.
I'd love to help, but I can't get them (we had a woman call and email about it) to send us photos. They supposedly bought a used kit from someone and won't show the photos of the bike or how they are trying to install the kit.:confused:
This is just my opinion but I don't think the problem lies with the lowering kit unless it has been altered
by someone. I have found Motowerks products are first class in every way.
Then to top the great product, you have the owner begging to let him help you on the forum. That is Outstanding Customer service. Speedy Keep up the great work.:thumb:
Almost sounds similar to the bad weld on the swing arm issue.
In any case, I have the mirror extenders, lowering link, foot peg lowering, highway peg mounts, If I was to have something made for me where my life could depend on it, Motowerks would be the place for me. Extreme precision and first class quality, just tried out the highway pegs in the garage, decided to turn the bike around to lube the chain, last maneuver moved the kickstand up, YUP over she goes and I can't stop it. Full tank of fuel,on top of the highway peg , no damage , just hard to get back up, as I don't have the strength that I had 7 years ago, retirement does that to you.
You know what would be nice is a latching mechanism for that dam kickstand, or a better kickstand.
1 - 20 of 26 Posts
