1 - 20 of 32 Posts
Hello i have a Versys that i bought in july. it has about 2500 miles, and think its great. the fueling is very good except right off of idle. when opening the throttle from closed say for a tight turn it is hard to be smooth. (jerky?) i read on the other Versy forum (http://www.versys.co.uk/index.php?option=com_smf&Itemid=45) about the TPS adjustment. so i tried it today. i have only ridden about 50 miles so far but it runs great and it seems to have made a big difference in the jerky low speed and on off throttle. has anybody else tried it? i will post again after i ride more miles, and also check the fuel milage. you need to register to see the post (with instructions) on the other forum its under technical discussions Partial throttle 2800rpm Lean stumble,surge cure now with pics!
Very interesting, invisabiker. Thanks for bringing it to our attention... According to the service manual, standard output voltage at main throttle sensor is: DC 1.005 ∼ 1.035 V at idle throttle opening, and DC 4.2 ∼ 4.4 V at full throttle opening.
Sub-throttle sensor standard output voltage: DC 0.4 ∼ 0.6 V at idle throttle opening, and DC 3.825 ∼ 3.975 V at full throttle opening.
Here is the link: http://www.versys.co.uk/index.php?option=com_smf&Itemid=45&topic=4157.0
Ignition timing advance is affected by TPS and RPM inputs. Idle RPM went up by pre-advancing ignition timing. It's normally 10° BTDC @ 1300 rpm to 33° BTDC @ 5000+ rpm. Any change at idle and higher rpm's could be checked with a timing light.
interesting you say the lean stumble problem now has a cure....i hate that... my bike does it while trying to cruise around that rpm... i will have to check it out
I had done this modification on my '08 Versys and have now done it on my '09. It smooths out the low speed running of the engine and I think it helps. Just my two cents worth.
The left TB's left IAP sensor hose fitting bore is larger than in the two TB vacuum access fittings. A 6" long, 1/8" ID hose on both TB vacuum access fittings which originally had the rubber caps on, works perfectly.
Ahhhhhh perfecto. Thanks for the info. Ive noticed a weird stumble at take off. Its starting to concern me. Guess its just made that way. I have Emgos on the way. Guess all mod this at the same time.
Just to confirm, this will help that stumble with no negative effects?
BTW
The suspension help worked perfectly!
It does smooth out throttle response at low speeds without any ill effect on mine. Adjusting the TPS up to spec also helps cure the low end lean stumble and exhaust pop, especially around 2800 rpm. Instead of going through the throuble of measuring TPS output voltage, you can try rotating your main throttle sensor by about 1/2 mm by relating to the green index mark. You can then rotate subthrottle sensor also counterclockwise to reduce cold-engine fast-idle rpm if desired...
http://www.kawasakiversys.com/forums/showthread.php?t=1412
Look at the main (grey) throttle sensor's green alignment mark on its front from near your front left flasher, and note how it ligns up. Loosen sensor screw with T25 Torx tool. Rotate sensor counterclockwise by about half a millimeter as seen on pic. Adjust, then tighten Torx screw. Main throttle sensor's new position:
Main throttle sensor Torx screw:
Fast idle may then be higher. You can rotate subthrottle sensor (black, just above main throttle sensor) also counterclockwise with T25 Torx screw to reduce cold fast-idle rpm. I rotated mine to its maximum counterclockwise position, to which it was already near. Subthrottle sensor's new position:
It is nice. But damn it hot right now!
Yeah they just mentioned on the news yesterday that the entire planet is in its record breaking hottest ever summer overall. Northern hemisphere feels the most heat increase. I'm way up north, 100 miles due south of James Bay tip (bottom of Hudson Bay) and it's been already too hot, often in the 90's ambient.
Invader, Fuel injected newbi question. why does the mileage suffer from these adjustments?
Donn
If adjusted within spec ... there is no milege penalty ... If it is a random ... guess and by golly ... then it could get worse ... The computer interputs voltage only .... which in reality is the throttle position ... the TPS adjustment effectively adjusts fuel ( tells the computer how long the injectors are squirting ) at a given throttle setting ... more ... or less ...
That's interesting. We've had a pretty mild summer in ND this year. Hardly broken into the 90s at all.
Something helped. Not sure if it was removing the sub throttle plates, or connecting the TB's vacuum fittings together, both of which I did today, but my low rpm hesitation is gone. I had installed a PC V and autotune when I switched to the Leo Vince GP pipe and blocked of the PAR valve. Even after a few weeks worth of accepting the autotune trim tables, I was still experiencing a bad miss in the lower gears at low rpm after downshifting for a corner, etc. One time it hiccupped so bad it shut the motor off. I would also notice it when blipping the throttle for downshifts to try and match the rpm's. I had already adjusted the TPS for the proper voltage range and as I mentioned earlier, the PC V and the autotune did nothing to help the problem. After a test ride earlier today, it looks like the problem is gone.
I had removed the subthrottle plates and PAIR valve, and replaced the stock exhaust system (+ tapered aluminum handlebars, etc) before my first ride on new Versys. I did the TPS adjustment, TB vacuum hose mod and TB vacuum synch adjustment later on... It already ran flawlessly, and it got even better after adjusting all my valves (in 0.18 mm/exh 0.26 mm) an indexing my spark plugs. MPG (57 per US gal: mixed city/hwy/bush roads), response, power and driveability is now better than ever. :thumb:
It did go up to 92.3, 93.4 and 94.3 in May, which was a bit alarming. Maximum in June was 83.5, and so far this month 87.1. It did go up to 100.94 in June 1995, and down to -45.4 in January 2004 (-49.54 in Jan 82).
This is actually one of the best summers in a long time after a couple of record breaking rainy and cool summers. It's been mostly sunny and dry, sitting in the low 80's to high 70's. :) I prefer being in the low 60's to low 70's.
I am getting an aftermarket exhaust in this week and want to do the PAIR mod. Can this be done with out taking the bike apart. Also I would like to see a pic of the mod, meaning what it looks like with just capping the ends, I want to make sure I am looking at the right hose to cap. thanks..
I sealed off the air suction valve on the valve cover with 1/4" aluminum plate, and the air source on the airbox with RTV silicone. I also removed the air switching valve unit by connecting its two wires together to prevent triggering the 'FI' warning light...
1 - 20 of 32 Posts
