1 - 14 of 14 Posts
I'm going to put a Metzeler Tourance rear tire on my V shortly, but am still trying to decide which front tire to use. I'm going to stay with the standard size, so that obviously means choosing something other than a Tourance.
My primary consideration is longevity. I know, from using Tourances for years on my old R1150GS, roughly what mileage I can expect from them. The front Tourance on my GS would always have more tread life left when the rear was ready to be changed, but I always changed both at the same time anyway. So, I only need a front that will last as long as a rear Tourance. Riding will be 95% paved roads.
As a frame of reference, I usually got between 8,000 and 9,000 miles out of a set of Tourances on my GS. I'm a fairly "sporty" rider, but find the Tourances provide more than adequate grip and excellent tread life. A couple of tires I'm considering are the Avon Distanzia and Storm 2 Ultra.
I'm sure there are more than a few here, who have done what I'm proposing. I'd appreciate any feedback you may have.
I really like the Distanzia on the front. I'm about to try that in combo with the Tourance rear, too.
What kind of mileage are you getting(or you think you'll get) out of the Distanzia front? Have you been pairing it with a Distanzia rear up till now? I'm leaning towards the Distanzia, but would just like some anecdotal evidence it will last long enough for me.
A poster who's "left the building", Gary down in South America, claimed to have more than 36,000 miles on his front Tourance 130/80, FWIW.
I'm going to predict about 8k for the Distanzia front. I went through a Pirelli Trail on the back, and I'm putting a used Tourance with about 60% tread life in its place.
Fasteddie, I'm aware of putting the Tourance 130 rear on the front, but I won't go up a size........especially on the front. Thanks, anyway.
Versystole, thanks for the reply. I guess my concern with the Distanzia is, I've heard it's a softer compound in the size needed for the V, because the 120/70-17 is really intended for supermotos.
The reason longevity is so important is because I'll be riding the bike from Ohio to North Carolina(near the coast) and using it there during the winter and early spring. About 1,500 miles will be accrued on the trip down and back. I figure I'll put on between 5 and 6,000 during my stay.
The other factor is, I change my own tires, but won't have the equipment to do so in NC. I won't consider taking it to a dealer, unless it's an absolute emergency. I've had too many bad experiences with dealers, so now do all my own servicing.
Avon Distanzia 120/70 SM front does wear relatively quickly with much cupping into rear of tread blocks... Continental Trail Attack would be a great choice.
http://www.motorcycle-superstore.com/2/29/393/14853/ITEM/Continental-Conti-Trail-Attack-Dual-Sport-Front-Tire.aspx?WT.ac=SLIsearch
(W speed rating is actually 168 mph)
http://www.conti-online.com/generator/www/de/en/continental/motorcycle/themes/motorcycletires/enduro/trailattack/trail_attack_en.html
Thanks for the links Invader. I've used the Conti Road Attacks on another bike previously. I loved the ride and grip they provided, but they were toast in under 4,000 miles. I understand the Trail Attacks are different, but because of my prior experience and the price($171.99 for a front tire!!!) I think I'll be going in another direction. I don't think I can justify paying for a W speed rated tire on the V. :D
I have the Conti TrailAttack 150/70 rear which I got when they were still low cost, with a 120/70 Distanzia. At 7000 miles on my TrailAttack rear, it's barely half worn.
I wouldn't worry about that speed rating. I was just noting it because they mistakingly rate it at 106 mph in motosuperstore link... Most 120/70 are at least W speed rated, but you don't want a street oriented front tire with your rear Tourance. So how about Pirelli Scorpion Trail?
http://www.motorcycle-superstore.com/2/29/393/14850/ITEM/Pirelli-Scorpion-Trail-Dual-Sport-Front-Tire.aspx?WT.ac=SLIsearch
120/70 R 17 M/C 58V TL
120/70 ZR 17 M/C 58W TL
http://www.pirelli.com/tyre/ww/en/motorcycle/sheet/scorpion_trail.html
I have the Pirelli Scorpion Trail for the front. Excellent grip in the dry and wet, confidence inspiring at the corners. I read a user who had it at 18000km and still counting.
Distanzias
Glazwegian - I recently mounted Distanzias in the 150 rear, and 120 front (Sm compound) on my green '09. Last weekend I rode from my house in Boulder, CO to Jackson, WY and back, about half on the Continental Divide Route. The whole trip was 1440 miles. I did have to save some time and hit I-80 and 191 in Wyoming and was doing around 80 mph basically the whole time that I was on pavement. To make a long story short - There is perceptible wear on the rear tire, but not the front (and the rear isn't that bad, just a tiny bit of squaring off due to the many miles of high-speed asphalt).
Hope that helps!!! :cheers:
Discussion Starter #13
Thanks guys, I appreciate all the replies. Time is getting short to make a decision, because I plan on leaving for NC Oct. 5th. I will stay in NC for a couple/three:D weeks, then rent a car to return to Ohio. A couple of months later, my wife, our dog and myself will return to NC for the winter.....where my V will be waiting.
I've looked hard at both the Scorpion Trail and the Conti Trail Attack. The Trail Attack has a wear resistant center tread(very important to me); the Scorpion Trail does not. This leaves me having to pay "big bucks" for the Trail Attack, or go with the Avon Storm 2 Ultra(a full on street oriented tire), which I'd hoped to avoid doing.
Invader, the W rating doesn't bother me in the least, just that I have to pay for that rating, and I'll never need it.
I'll be sure to post here when I've made my decision(probably in the next few days).
Discussion Starter #14
I've purchased and received new tires for my V, and will mount them on their respective rims in a couple of days.
I decided on Avon Storm 2 Ultra's for both the front and rear wheels. I didn't go with a Tourance on the rear because of my ongoing experience with the OEM tires. I've now got almost 3,500 miles on them and it looks like I might be able to accumulate 6,000, or more, if I were to keep using them. This is amazing to me, as I've never gotten more than about 4,000 miles on a set of OEM tires previously, regardless of model of bike. Primarily, I think this is because the V is lighter, has a lower hp rating and less torque, than any bike I've owned in many years. Just another reason to love the V.....especially with the high cost of tires today.
I had a good experience with the previous version of the Storm 2 Ultra, so that weighed heavily when making my final choice. Hopefully, it's a good one. If not, I'll just have to curtail my riding while in NC.....not a pleasant prospect.
1 - 14 of 14 Posts
