1 - 20 of 30 Posts
Hola,
I have Versys 650 2018 model, and I wish to buy top case holde and case also.
But I have problem, I found from GIVI rack - Givi SR4114
And from SW-motech steel rack and aluminum rack.
But here is problem, Givi have weight limit 6kg and SW-Motech have 7.5 kg weight limit.
Now i wish to buy this case TREKKER OUTBACK 42.
Now I heard that this case is 5-6 kg alone empty. So if you check weight limit for racks, you can see that for Givi that is it i can only ride with empty case, but with SW-Motech I can add 1.5-2 kg into case and that is it.
But when i see this racks it is really thick steel and only this little weight limit.
I study mechanical engineering, and when i see this parts my knowledge say to me that this parts need to take much more weight than manufacturer say.
Which rack you have on your bikes, and did you always whatch on weight limit, or you ignore and just add stuff inside and ride.
I mean I don't want to find myself in a situation where holder will break and maybe disbalance me on bike and crash bike with me into ditch or somewhere else.
Or best solution is to build alone holder with strong and thick steel and that is it?
Two things to think about
(1) how adding all that weight that high effects handling?
(2) are you over stressing the motorcycle frame?
Yes, I will not adding to much weight into case, but I wish to know how much I can add but without damage frame where is rack connect to motorbike. I know that will affect on handling. If is something really heavy I always can place that on passenger place and low weight into case.
For now I don't have saddlebags or case, so for now I all my stuff have in may backpack and second backpack is on passenger place.
Usually the topcase brands are too carefull regarding weight and speed limit recomendations.
If I'm not mistaken the weight limit of the cases that came with my 2018 Grand Tourer (made by Givi) is 5kg for the side cases and 10kg for the topcase (a rebranded Givi V47) and a speed limit of 120 km/h. If the frame can take my 130kg of weight for sure it can take some kg in the side and topcase. But the stress it causes in the supports is a totally different story.
I would suggest to look at the Givi V47 as it is lighter and this can help.
Yea, that is what I wish to know, how much support can take weight without problem.
I also look for that Givi V47, but I wish to take aluminum, it is stronger, (and also I will put military mate green vinyl on them so he will be simmilar color to my bike) but he have less place than this Givi V47.
I will wait till Christmas, than will be discounts on everything, I will found something nice for my motorbike :)
I’m using the givi rack myself with a plastic pad and OBKN58 liter top case. Max I’ve loaded it was 17kg (case inclusive) and rode for 7K km+, top speed was ~170km/h.
This was together with side cases (trekker outback 48 liter pair) and a pillion. All in all weighing around 500kg with me, pillion, bike and stuff.
No issues what so ever, just less mileage from the rear tire.
This is what I wait.
Thank you, so this 6kg weight limit i can easy add 10 kg (including box) on tham without problem.
You have this rack - Givi SR4114, or maybe some other from givi which I didn't found? for gen 3 versys 650.
I’m using this combo:
PL4114CAM
SR4114
GIVI Plate For Fz Monoracks (M7)
PL4114CAM bolts to SR4114 and sits there rock solidly.
An expensive set, overall, but the quality and reliability is superior
PL4114CAM
SR4114
Thank you very much, now I am 99% sure that rack are strong and can take more weight than manufacturer say, than I will take this combination:
Givi SR4114
TREKKER OUTBACK 42
GIVI M7 Monokey (same like yours)
Now only need to wait Christmas and paycheck in december :)
Givi SR4114
TREKKER OUTBACK 42
Should do good :)
If at some point in time you decide to get the side panniers as well - don’t rush out to buy lock cylinders, it takes patience but is easy to re-code them yourself. Got 6 Givi locks (tank bag, panniers, top case, 2x tool boxes) - all match one and the same key after a bit of patience and trial and errors :)
Should end up saving 50-60 euros
Should do good :)
Maybe in future I will need side racks, but who know maybe until then I buy Versys 1000 :) ( for now 650 are badass and more than enough for me )
Here is answer from GIVI about weight limit for SR4114 Rack:
Looking further into your enquiry I have physically checked one of our SR4114 Racks, and can confirm this has a maximum load allowed of 6kg.
You should still be ok to use the OBKN42A, as the 6kg maximum weight load refers to the contents carried inside the Top Box, and not the overall weight of the Top Box itself and its contents.
Bear in mind that you can easily ride w/ a passenger that WILL weigh much more than 6 KG.
Here are pics of my '09 and '15 V650s set-up for camping, on rides to Dawson City and Alaska, and across Canada. I weigh about 200 pounds wearing my ATGATT stuff.
and these pics show that 'stuff' OFF the bike....
Discussion Starter #14
Hmm I don't know why but I don't see pictures (when I quote your answer than I was able to see links but pictures are 1x1 pixel)
I know that passenger weight much more than 6 kg, but he seat on passenger place, and also he can rely on the case , I was worried how much strong is part on motorbike where you connect rack to him. (like on picture).
But now I know that people use much more weight than specs recomended, so I am sure it will be OK.
SW-Motech say this in instruction :
ATTENTION: maximum load: 7.5 kg/16.5lbs (including topcase/luggage and Adapter Kit)! The maximum vehicle load specified by manufacturer must not be exceeded!
Maximum speed with mounted topcase/luggage: 130km/h
So when I translate that to my language I understand that: topcase weight + luggage (inside case) weight need to be maximum 7.5 kg
But Givi say, that I can add 6 kg inside case, no matter how much weight that case.
That was little confusing to me.
My camping gear weight is usually 15 Lbs in topcase, 15 Lbs in each pannier & 25 Lbs on the rear seat. I always take a small ice cooler with my food in it iced down.I usually put the cooler in the topcase. My next trip I’m thinking about putting the cooler in a duffle bag or seat bag with other stuff on the rear seat. Most of my Motorcycle Trips I always tent camp. Only one trip did I stay in motels. A week of camping & total expenses is usually $400 dollars,a week staying in motels $800 ++ dollars. I like coming home & still have money left over for my next trip!!!
I've ridden literally thousands of kilometers with a 15kg topcase with speeds far exceeding the stated 130km/h. I've also known others that did so. Last month we finished a 3500 km trip around the Alps where a friend's CBR 600 F4i carried a Givi V47 that weighed around 20kg (case + contents) attached via this: https://www.givi.it/my-motorcycle/product/honda/cbr-600-f-99--09/optionals/252f . No issues whatsoever, wasn't his first trip either.
I've seen overloaded luggage racks bending or breaking only on old, small bikes. Once on a Honda CB 500 and once on a Suzuki GS 500 (that one actually broke through a subframe mount, due to rust). In both cases, you could plainly see, by the construction of the rack, that it was not up for the job. The rails were too flimsy, it stuck out too much to the back, creating a large lever arm, the entire bike was shimmying when loaded...
On any bike where the rack looked right, it also took heavy loads just fine, yet the producer's load and speed limits were the same for all motorcycles. Lowest common denominator? That's my guess.
Givi or SW-Motech probably can't be bothered to test their designs until the breaking point. There's way too many bikes and racks to cover. Instead, they likely have a standardized "pass/fail" test with like a 5kg load (or even no test at all, just an engineer signing off that it should be fine ;)) so all their warnings labels use that.
I can vouch for the OEM luggage rack on the Versys, it's as low-profile as it gets, very sturdy, doesn't stick out too much. It's surprising how well the bike handles with heavy load.
Discussion Starter #17
I was looking also OEM rack, but when I see price :huh: i just close that page on internet, and after 15 minute found Givi :)
Those specifications are written by the "corporate lawyers" I believe.
Discussion Starter #19
Yea, probably, so they can keep away from lawsuits if rack break and accident occurs because of that, and you use less weight than what they recommended.
Also now I see all pictures which you add . I was worried about few kg extra, but when I look this pictures ( yours and from Rokas Mažeika ) 100% I can be sure that racks are hardcore and durable :)
Discussion Starter #20
Should do good :)
Hola, it is me again :)
Maybe stupid question but I need to ask.
When you lock top box, are you able to take off box from top plate, or you need to unlock box and then you are able to take off from top plate?
I mean to say, is there any safety mechanisam so nobody will be able to steal my top box without using force?
I don't know anybody who own GIVI top box, so I need to ask that.
1 - 20 of 30 Posts
