1 - 20 of 21 Posts
Hey,
I have a '10 new versys model (with 3.000km in it) and it's spending fuel like a crazy horse!!! it's spending 7l/100km, or, MPG: 32.8 .
My riding is only in town, doing 8km twice or 4 times a day, with a LOT of stops due to Traffic light.
Can anyone tell me some tips ou tricks to reduced in a bit (lot) this consumption?
Best regards!
I would be interested to know also since mine has dropped from 380kms to 340kms a tank...not a big drop but the other day I ran out of fuel due to this.
I'm not a scientist, but I've read that increased ethanol content will decrease kpg/mpg. My understanding is that the ethanol does not burn as well as gasoline (or something like that). Therefore, the engine runs less efficiently. Has there been a recent change in gasoline/ethanol mixture? I have always had about 48 mpg with a mix of highway/town riding.
In the US, I believe current ethanol content is about 10%. As long as I've been riding, the ethanol content has been the same. I recently read that the US government will allow a 20% ethanol content in the fairly near future. Gas stations will need to clearly indicate what pumps are using the 20% mixture, as this will adversely effect many older vehicles.
4
Guest
cold weather knocks off the milage on mine from around 200 to 180. but thats low even in town. Checking the TPs would be my first port of call. Or go for a decent run and see where fuel bars go? will give a rough idea if town/your riding is responsible? Going mad or slow seesm to return smilair milage on these by the way.
On my V, I’ve been getting right around 50 MPG all summer (temps between 70°-90°). Now that the temps have dropped into the low 50°s & 40°s the mileage has dropped as low as 41 MPG — And it’s not a “winter mix/ethanol” issue because when we get an unusually warm day (70°s) the MPG goes right back up to around 50.
My other bike (an ’86 Honda Shadow w/carburetors) would consistently do the same thing.
This seemed counter intuitive to me because the colder/denser air should contain more oxygen and (at least with the carbs) be likely to produce more power... but my buddy (a pilot) suggested that it may actually be due to the increased wind resistance of the colder/denser air.
4
Guest
colder/denser air does contain more oxygen = hence more fuel required to maintain ratio.
Mine has always gotten lousy gas mileage around town, and I will be interested to see if it improves after I get my valves serviced. Everything else is spot on. Even though your bike is new, it could be that your valves need adjusting. You would not be the first new V that needed this. In fact, it's probably a good idea to do it after a couple thousand KM break in anyways.
Anyone else care to comment along this line?
But the V does not have an O2 sensor, in North America anyways.
I've ridden in other conditions before comming to town and I've done as much as 48 mpg... so I suspect it might be my driving skills (or lack of)
Ethanol has a lower energy content that gasoline. A 10% ethanol fuel mixture gets about 10% less miles per gallon than gasoline. I was riding once from Cincinnati to Memphis and was getting 135 miles per tank on my Honda before having to flip to reserve. I filled up at a Love's gas stop that had the 10% ethanol mix and had to flip at 125 miles. I filled up the same, rode the same (75 mph cruising on the highway), same conditions, same direction.
The other consideration is how hard you turn the throttle at each and every redlight?
Just wanted to mention the usefulness of a free site, http://fuelly.com , for tracking MPG on all your vehicles. (I have no relationship with them other than being a user.) You can search for like vehicles and see how you're doing against others with the same one, plus you get lots of stats on average MPG, average fuel-up costs, etc. According to that site, I'm getting 48 MPG with a still breaking-in V.
I'm getting about 50 miles per gallon/ give er take....even when I go out to play WOT drops it only to around 45. You have other issues. I agree with 133bhp, check your tire pressure & your chain...are you riding around in traffic with your foot on the brake? I know it sounds dumb but look around, people do it. also when its cold your motor does not reach operating temp & then you dont get full combustion= waste more fuel, but not that much.:goodluck:
oh yeah we have the ethanol blend all year here in Colorado and I run all over town,City Highway even into the mountains above 10,000 feet. no problems.:dgi:
4
Guest
True, but does have an intake temp sensor. Cam timinmg, rather than valves will result in wasted fuel. Possible if no clearance, valves will burn/leak, typically resulting in low compression, blowback etc. but you'd have other troubles/would notice it.
Granted its new, but assuming air filter is free of crap/oil? But could be Fuel pressure regulator, temp stat stuck open, TPS, ECU and so on. But Like I said, first I think you need to be sure you have a problem? check the exhuast is not really black? or chop the plugs, or simply take it for a good run, ideally a tankful. If still subtsantially low, (suspect it will be normal?) you know then somehrings not right?
just occured to me, ( I;m so used to doing my own maintennace! ) - who cares? its new! confirm fuel consumption then just take it to the dealer, let them sort it. :)
In colder weather the gas is more dense therefore you
pack more per charge in the cylinder. Do they still make "Cool Cans"?
A recent book i read had a group riding identical BMW's, one of the riders was complaining about poor fuel consumption so rather than fiddle with the bike they changed the rider around and you guessed it, the bike he now on starting suffering from poor fuel consumption, from memory he was all over the place with the throttle and heavy braking. Just a thought
Make sure the coolant temperature is running hot enough. If it's too cool, the ECU will richen up the mixture to compensate. You could have a bad thermostat or coolant temp sensor.
My bikes speedometre is way off it's mark (around 6-7 mph @ 60 mph) :huh:
Since distance is related to mph, this will account for even worst mpg than what I actualy get :thumbdown:
So as long as it's (the bike) going good, I'm not bothering to much with mpg
LOP
1 - 20 of 21 Posts
