1 - 13 of 13 Posts
My solution appears to be similar to Chris's posted here a few days ago, but the only additional parts I used were longer mounting bolts. The hardest part was removing the oem tag light wire.
Here's the pics: (click to enlarge)
After removing the tag light I removed the lower fender with a coping saw. Using a hobby rasp (file) and sandpaper I smoothed the cut. Then, I held the oem tag bracket upside down where I wanted it and used an awl to mark where the mounting holes were to be drilled in the remaining fender. You can change the angle of the tag depending on what angle you mount the bracket. A quick trip to Ace Hardware secured the longer stainless button (allen head) screws and washers I needed to mount the bracket. (I believe they were 6m x 20.) I also picked a couple of shorter 5m stainless button head screws and acorn nuts to mount the tag. I used blue Locktight with the bracket screws as there is no way to torque them down tight against the bracket without some sort of spacer. From start to finish it took me about an hour and a half and it's really a very clean look once you're finished. The scratches I made when marking the bracket mounting holes are covered with the tag as is the entire area where the cut is made.
Like Chris, I'll replace it with something aftermarket if something that looks better comes along.
Thanks for the step-by-step instructions and the photos, Lanesplitter. I'm picking up my Versys today . . . which, according to our local weather wizards, will be the last tolerable day before three days of storms and 3"-4" of rain descend on us. So, I'll have a good reason to spend some time in the garage making the Versys's rear end look better. Using my standard formula for converting the time estimates given by guys who are handy with tools to the time necessary for guys like me who are hopeless klutzes, I'm figuring I will need about 6-8 hours to accomplish something like you've attained! :eek:
I'll report the outcome, but I hereby release you (and Chris) from any responsibility for what I produce and/or accidents that occur during the process . . .
Kevin
Good job
I took a look at mine the other day, and that was the same idea I had. I figured that would look the best. Good work and thanks for the step by step.
Discussion Starter · #7 ·
Technically I should have an operating tag light, and I'll install one eventually. Although the cops could use it as probable cause to stop me most won't even bother.
thanks lanesplitter, after looking at all the different mod designs i went with yours, i was thinking of something like this but i kept getting hung up on the tag light, until i saw some led license plate bolts at the local cycle gear. i have yet to install those, i will look at it at night and see if the running light lights it up enough. but it was super simple and only took an hour. thanks again.
Discussion Starter · #9 ·
I'm glad the post helped amschemel. I still haven't installed a tag light but when I do I'll probably go the LED route myself. I'm thinking just drill a small hole in the plastic above the tag, install the light and tap into the existing tag light wiring for power.
honestly i think the brake light, (while operating as a running light) illuminates the plate enough, but who knows if the police will see it that way.
Discussion Starter · #12 ·
Having been a cop in another life I can tell you that getting a ticket for no tag light on a motorcycle means that 1) you've been a total ass or 2) you've just been stopped by a total ass. Either way the odds are not very good that it will happen.
And speaking of rear ends - I'm kinda proud of mine :D
I did a similar tail mod this season and ran for awhile with the running light illuminating the plate. I wasn't stopped but did eventually mount an LED in the upper center of the plate - just so there would hopefully be no problems and even though I couldn't find a requirement for such lighting in our state's moto regs.
1 - 13 of 13 Posts
