1 - 10 of 10 Posts
Hey Guys,
I have this strange ticking sound that has started between 3 and 4 thousand RPM in 3rd and 4th gears. Has not affected performance and shifts fine. Any one else see this happen yet?
Just give a second look at the chain, might be out of alignment with the back sprocket or slag might not be right.
Anyway did you do this chain and sprocket work by yourself or was done by others.
Ticking sound
Did the work myself. Chain did have a sway to it. Seems to get less as I tightened it a little. Seems to be a sound that would come from the muffler if you were to tap the chain against it. Probably will tighten it a bit more in the morning to see it I can eliminate it all together.
Double check the alignment as well, you're not one mark off? No?
The Alignment marks seem to be fairly accurate, but you can check now if you haven't before. Measure or String Method both work. Dead on?
Eyeball the rear sprocket as you spin the wheel- does it rotate in plane? About 1/8" out is normal I've heard, but that shouldn't make it slap the exhaust can.
There is a section where you can see the chain swing from side to side on the rear sprocket. It stands out as it makes the return run next to the exhaust that there is a bit of a bend. Not much of one, but you can see it. Tightened the chain this morning a bit and did not hear it as much, but just every now and then. Chain was suggested by a Bike Bandit tech, Western Power Sports. It is smooth. I will say that much, but hay. I rode the last chain to 41K miles so it has to be an improvement. Right? :D
Scared me when I read this post heading. I just came of a Yamaha FJR1300, and they had quite a few where the valve guides wore out early. They would get a "Ticking" sound and that is how you could tell. But, I had 80K on mine and never had a glitch on that motor.
Probably chain or sprocket as mentioned.
Hey All. I just did a little checking and a noticed that my "sway" in the chain is what started making my clinking sound against my muffler and is working itself out.
1 - 10 of 10 Posts
