1 - 3 of 3 Posts
I was wondering if anyone has lubed their throttle cable. I just did my clutch, but I can't figure out how to get to the throttle cable to lube it with one of those clamp-on then spray cable lubing tools.
You need to remove the plastic enclosure at the end of the throttle tube on the handle bars. Once this is removed you can attach the cable lube tool. Rust Check works great as a lubricant.
1 - 3 of 3 Posts
