1 - 2 of 2 Posts
When doing the valve clearance check I added the extended vacuum tubes as per Onewizards suggestion. The sync is out a bit. When I tried to adjust it I could not get a screwdriver to the adjustment screw, manual indicates you require a special Kawi tool “pilot screw adjuster 57001-1603”. Is there a more generic tool that can be used? Make model of tool?
1 - 2 of 2 Posts
