1 - 20 of 21 Posts
Hi everyone.
I finally have found 2 bikes that I can possibly have a chance to buy this weekend. 1, a 2008 red with 7,750 miles that I was not allowed to testdrive, and 2, a 2009 with 11,000 miles which I am allowed and will be checking out today.
Are there any suggestions on what I should be checking during the ride?
Any tips on what I should do while riding?
Used Car test driving has taught me to ride it on the freeway if possible and to go through the gears, and then also let it sit and idle to see how it performs once hot and check for oil, coolant drips and or overheating, fans working. I'm assuming the same is with a bike?
Thanks!
Hi everyone.
Used Car test driving has taught me to ride it on the freeway if possible and to go through the gears, and then also let it sit and idle to see how it performs once hot and check for oil, coolant drips and or overheating, fans working. I'm assuming the same is with a bike? Vibration noises from fairing rattling are not a bad thing as they can easily be fixed with some double sided foam tape. After market parts can be worth a lot if they are what you want.
Thanks!
Ignore the year. They are identical. I would look for signs of accident damage and tip over damage although it is not all bad if bike was dropped a few times. Also factor in cost of replacing tires if the tires are near wear bars, check chain condition as it will be a window on how bike was cared for.
Bike looks clean. Very clean. It is in an upscale neiborhood so I'm hoping that all maintenance has been done up to now and that it has been serviced by a pro. Hoping.
The only thing I am unsure of by pics is this:
Looks like an oil gauge or something. I'll make sure to inspect it in person, but is there anything I should look out for? Read on other posts where it was more of a distraction to look at, but if it works, should I consider what digits come up?
That is non standard. Ask owner. Looks like a 12V accessory socket.
...Are there any suggestions on what I should be checking during the ride?
Any tips on what I should do while riding?...
Check UP and DOWN thru the gears for clutch-action, smoothness, any unusual noises, throttle action. Up to freeway speed IF possible (or revs to 5,500 in a gear, as that's about the revs for 75 mph - 132 km/hr) checking that it feels OK.
Brakes, front and rear for effectiveness, and look at the discs for scoring. No leaks; chain seems properly tensioned (1 to 1.4" play); tires for tread, etc.
IF the rest looks OK, you're probably good-to-go!
PS I have one of EACH - an '08 and an '09....:thumb: - :thumb:
thats a wolo airhorn... a very common mod here as the stock horn isnt that loud...
Oh, Nice. Always wanted an airhorn on my other bike. Well, hope this one works out, cause it's 30 VS an 80 mile drive, and the 09 looks much nicer than the 08.. cosmetic-wise at least.
Thanks for all the input!
Some 2008's had a frame issue and stick coil problem also if i remember right.
Frame issues? 2008, 2009?
CA only approves of 2009 and later if I'm correct, but I'd want to steer clear of frame issues!
2008's only....
Discussion Starter #16
Well I'm glad I was able to test drive it. Took it for a spin out the lot and into the freeway for about a 5 mile round trip ride.
First of all, other than just falling in love with the versys, and all the great things I hear about it, and the numerous options to make it a great commuter/tourer... I have never ridden or driven one until now.
Talk about low end power. Felt Like I was riding a pick up truck or a jeep. Quickly reached high speeds, though I'm assuming original sprockets, it felt a bit high on the revs.
No noise from the windscreen and it had an after market tall one, but lots of wind noise at that altitude regardless. Did I mention that I'm 5, 41/2 feet short? This bike was tall. I felt like I almost could have gone down if it wasn't for me sliding my butt to the sides. The seat was also aftermarket and higher than the stock one on the 08 I sat on last week.
Overall, the Bike ran great, and looked great. Now I just really need to decide if it's for me.
Thanks for all the feed back. I may soon be a new Versys Owner.
Ouch! Honda's are made for short people. Try one of those VFR's. It killed me from leg/knee/calf cramps. You may fit perfect on it, and it is a nice bike o/w.
Yeah, the Vs. 650 is the tallest I've ridden too. It takes getting used to for most anybody under 6'-2".
Discussion Starter #18
@ Kawdog, lol, my calves cramped up from the test ride.. and left side of my back hurts this morning. If I get Iit, Im slicing that seat in half.. Im 135lbs so I dont think I even made a dent in that seat. Riding it was never an issue.. the mount/dismount was a workout though.
Yea you might want to try a Susuki SV650. My son is 5'7 and really loves his SV, he has the naked version but a windscreen could be added. He has rode my V but didn't like how tall it is. The SV is similar in power and ride ability and are priced similar as well. Good luck with your search.
1 - 20 of 21 Posts
