1 - 11 of 11 Posts
installed motowerks lowering block last week ( another fine product from speedy) and when i lifted up swing arm to install shock ther seemed to be a slight play is this normal from just taking the weight off of it or not it was tight moving swingarm side to side and no i have not regreased that is one of my winter jobs thanks for any replys.
Yes, it's normal. There is freeplay at the shock's needle bearing bottom mount on the bolt. There is more travel at the end of swingarm in relation to shock travel.
Flatwoods,
I have a lowering block on the way from another forum member. How hard is it to install? I know there are directions on Speedy's website, but sometimes reality is different that whats on paper. How hard is it to cut the kickstand? I already have the flatfoot from Speedy. I also bought some swing arm spools to aid in lifting the back end of the bike. Did you use a spool arm lifter to raise the bike, or something else>
Thanks
Jason
Flatwoods,
Thanks
Jason
You cant lift the rear by the spools to install the lowering kit. I had help and lifted the bike up and had my wife slide jack stands (with rags) under the driver footpeg brackets. This allows the rear wheel to be in the air and able to remove the bottom rear shock bolt.
Cutting the kickstand with a hack saw was easy to do even while on the bike. The kickstand was easier than lowering but the lowering was not bad.
Don't forget that it is recommended by many to lower the front as well.
http://www.kawasakiversys.com/forums/showpost.php?p=85847&postcount=161
http://www.kawasakiversys.com/forums/showpost.php?p=193999&postcount=229
Flatwoods,
Thanks
Jason
you have to lift the bike from the chasis...the shock assy is between the chasis and the swing arm. If you just support by the spools you'll be VERY unhappy when you unbolt the shock. I would recomend visiting the motowerks web site to get the instructions before opening your tool box:goodluck:
+1 on Captain Kirk's suggestions. I used a Dremel tool with a cut-off wheel to cut the kickstand. Suggest you cut gradually, 1/4" at a time, till you're happy with the lean-over.
I used my trolley jack under the muffler using a flat piece of timber to protect the muffler and spread the load. I also tied the handlebars to a beam in the ceiling of the carport.
I used a hacksaw to cut the sidestand it was easier than I expected.
Follow Speedy's instructions and you won't go wrong
thanks invader, merlin it was very easy to install top notch parts, i always thought the stock kick stand made the bike lean over to much so imeasured down inch and three quarters its perfect for me now.i raised the bike up with swingarm stand and put 5 gallon buckets under footpegs worked great,
If you lower the rear, you must also lower the front, because lowering just the rear increases front end trail to the point that it won't want to turn in without pushing it down into the corner. I lowered my front to the point where the fork leg changes diameter, and it handles just fine.
1 - 11 of 11 Posts
