1 - 17 of 17 Posts
Crappy installation instructions aside, this install SUCKED. it seemed way more complicated then it should have been.
Two pieces of advice to others:
1: remove all plastic fairings FIRST, top and middle. Also remove the front chain guard plastic piece.
2: BEFORE tightening down the front mount point on the right side, re-attach the middle(silver) fairing. Otherwise you will have to bend it a little to get it back in place after tightening the front mount point.
I think that's it. Anyone else have a similar experience?
Yes, they look great and I get my highway pegs today to install tonight. That was the motivation to get the bars really. I have a long trip coming(800ish miles) and after a day long, 300 mile trip my knees were killing me from not being able to stretch out.
I thought it was pretty easy. Some of the plastic that they said to remove, I just bent out of the way. The u bolt and plastic wrap upper rear mount is just cheesy, though, IMHO. 2009, YMMV.
I read threads here occasionally of people having all sorts of problems with this install. Not my experience.
Was there suppose to be instructions?:confused: All that came with mine was a sheet with a picture diagram and a parts list.. I will admit it wasn't a hard task though and I didn't remove any plastic.. I took the small hex bolts out of the lower radiator cowling and they moved enough out of the way that it was a breeze. It was an easy install, I just looked at the pictures close, looked at the mounting points on the bike, and slapped them on.. No vibes and they seem solid..
I found the install ok, time consuming and tough work but ok in the end.
I found putting on the SW Motech Engine Guard a lot harder.
Also just fitted the SW Motech rear pannier racks, that was also a bit time consuming but it moved pretty quickly after the blinker relocation.
All SW Motech instructions are available as downloadable PDF files on the SW Motech page for each product under the Additional Information tab.
I don't remember it being a big deal...The alien instructions aren't to difficult to follow. I don't remember taking plastic off....Maybe the '10+ models are different.
I can say they work!
only issue I had with mine was installing the wrong bolts on the front and jacking up the pieces on the engine that the nuts lock into, had to wedge a flathead in there to keep the nut from turning. Otherwise, it wasn't too bad. Oh, and the bolt that runs from side to side is a little odd to figure out.
pegs
06extn. just wondering what pegs you mounted and where you got them. I have the sw bars and am having a hard time finding peg mounts to fit 7/8 bars.
Somewhere on the forum I started a thread on a potential hazard with the bolt that runs through the frame. Make sure it clears the cabling.
A tip from my second install is that the U bolts need to be loosely attached in order to align the above long bolt with the crash bars. You need to hold the nut with a spanner on one side of the bike while you tighten the bolt with your socket set on the other. A second person makes tightening this bolt easier but you can lean over the bike and hold both tools at once.
+1 on a second person. Redline helped me with my install and his assistance was enormously helpful.
I did my SW bars on my 2009 in about 90 minutes by myself. No big deal. Been pondering highway pegs.
1 - 17 of 17 Posts
