1 - 20 of 35 Posts
Folks,
I did a search, but I can't find a clear answer. I have the Givi PL447 side racks. Does anyone know if they are compatible with the SW-MOTECH Alu-Rack Toprack? That toprack looks like the OE which I know won't fly with the OE Givi side mounts, but I don't know about the PL447s. I'm not interested in getting a topcase...I just want a stable place to mount some extra fuel. I could go with the Givi Fz447, but it has a big hole in it and it isn't flat.
Any suggestions? Thanks in advance for the help.
From what I understand they are not compatible. However, you can use the Monokey panniers with the SW-Motech Evo rack and it is compatible with the tail rack.
That was the direction I went with mine, but I went with the Trax panniers.
Maloy
Folks,
The adapter plate on the FZ447 is removable. If you want a flat plate, you could just get some steel plate, drill the appropriate holes, and attach it.
I have a Kappa KZ447 rack, which I believe is equivalent to the Givi rack. The Kappa plates that are compatible to the rack are the KM11, KM5, and KM5M.
So, you could get a KM11, and still have the option to use a Monokey topcase in the future.
Dave C
Thanks for the responses, guys.
Maloy, I dig the Motech Toprack so much because it replaces the cheezy plastic grab rails and looks great with nothing on it. Your's so far is the best picture yet I can find with that rack installed. It looks like it might be that small vertical piece that slips under the back end of the OE grab rails on the Givi that keeps the two from working together.
However, thanks to Dave for letting me know that adapter comes off. I hit your link and saw the .pdf instructions and it looks like it would be easy to cut a flat plate an bolt it down. I'd still have the bolt heads sticking up, but could find a spacer I'm sure.
I wish the MOTECH would fit, but the GIVI/KAPPA looks like it should do the job.
If anyone else has any suggestions, I'd love to hear 'em. Thanks!
The SW-Motech ALU-Rackack (same as the OEM rear rack) will mount with any side rack that has a flat surface where the side rack mounts to the subframe assembly, under the seat. If the rack you intend to use is flat (at that point, since the rack mounts "swoop" aft), then it will work. You will just need to source some longer bolts that will reach through both the side rack and rear rack.
If the PL447 sideracks maintain the mounting of the stock grab handles, then they should allow for the mounting of the SW-Motech ALU-Rack.
Just as both the stock side racks and rear rack can be made to fit together with a little cutting and grinding, I don't doubt you could get the PL447 and the SW-Motech racks to go together with the same.
Hope it works out.
is this on 2010 model or older? I have on mine 2010 side Evo rack with alu cases and I'm googling for confirmation that top rack can also be installed (but unrecommended by sw motech :)).
I wrote to SW motech and ask them why all racks can't co-exstist, but all I got was some shaddow answer that it's impossimble to mount it??!
I have these side cases: http://www.twistedthrottle.com/trade/productview/5450/788/ that are bolted right on top of the SWMOTECH rack. Seat still works just fine.
Would you mind posting some closeup photos??? I have been tossing the idea of adding side racks (have the SW Motech alu-rack). You mention bolting it right on top??
A parts list from TT would be great along with your photos. I just might take the plunge!
Thanks in advance
Thanks in advance
Yeah, I'll try to get that done today.
PARTS LIST FOR 2010 KAWASAKI VERSYS
SADDLEBAG SUPPORTS $229.99
GIVI V35 SADDLEBAGS $490.50
SW-MOTECH ALU-RACK $149.99
TOTAL: $870.48 (Plus S&H)
The cut out in the seat for the factory grab handles doesn't quite clear all the brackets, but I'm sure it would if you shimmed up the seat brackets with a couple washers.
Just use the spacers supplied with the ALU-RACK (to keep rack off paint), and bolt the GIVI mounts right on top of that. The bolts supplied with the GIVI racks do go through both sets of brackets and into where the factory handles were mounted, however, you should get new, longer bolts that use all of the available threads in the bike frame. USE BLUE LOCKTITE ON ALL OF THIS!!!!! You don't want to be, oh lets say, 1200 miles from home on a pass in Colorado without the right tools and have a saddlebag bracket come loose.
By the way . . .the trunk in that last picture is for sale.
Thanks for the parts list and photos!
Maybe SW says they cant be used together because the seat is a little tight and you must use longer hardware. But the proof is in the pudding! :thumb:
well the actual reason swmotech and givi topracks dont "work" with their sideracks is a legal issue of over weighting the rear of the bike.
Kawasaki's legal does not allow companies to make both available or advertise them as compatible. Even though, thanks to a couple brave pioneers, we know that they will work together.
If you give twisted throttle a call they will explain it a little better but its not that it wont work as much as they have prohibited marketing of both being compatible.
It makes sense, when i have my soft bags loaded and my top rack loaded and my wife on the back... it makes it very wheelie prone. :yeahsmile::D;):thumb::):usa:
Damn, that's the opposite of how I understood it... :confused:
Re: Contact Us by email
Thursday, July 7, 2011 5:43 PM
From: "Paul XXXXX" <[email protected]>View contact details
To: "Info twistedthrottle" <[email protected]>
Well, damn! But thanks for the info! :)
--- On Thu, 7/7/11, Info twistedthrottle <[email protected]> wrote:
Subject: Re: Contact Us by email
To: [email protected]
Date: Thursday, July 7, 2011, 2:29 PM
Paul,
They physically do not fit together. They would occupy the same space.
Regards,
Rich
On Wed, Jul 6, 2011 at 3:44 PM, <[email protected]> wrote:
Name:
Paul XXXXX
Telephone number:
727-8XX-XXXX
Your Bike Color/Year/Make/Model:
2011 Kawasaki Versys
Your Comments or Questions:
I spoke with someone there briefly about this... I just want to clarify compatibility between the SW-Motech top rack (Alu-rack) and the quick-release side racks. Both items' page clearly states they're incompatible with each other. My question is, are they PHYSICALLY incompatible, or is it that the top and side racks will bolt up, but SW-Motech (and Givi) believe that the Versys subframe has insufficient strength and don't want the liability? Thanks!
___________________________________
Twisted Throttle LLC
1080 Kingstown Rd, Building 1
Peace Dale, RI 02879
401-284-4200 (phone)
401-223-6954 (fax)
[email protected]
- ag streak-
well per this thread and others evidence, we know that to be untrue... the swmotech side rack and top rack do fit together, just like with the givi siderack because they mount on that back bolt the same way.
They technically do "occupy the same space" but what psycho has done is stack them and use a longer bolt, making them work together. So TT didn't lie to you, they are not made to work together, but rather the opposite. but they WILL WORK with slight mods
This image is the two "occupying the same space"
- ag streak-
They technically do "occupy the same space" but what psycho has done is stack them and use a longer bolt, making them work together. So TT didn't lie to you, they are not made to work together, but rather the opposite. but they WILL WORK with slight mods.
You know what I think? When I mounted my SW-Motech quick-release side racks, the spacer under the rear bolt that rides in the circular well on the bike seemed really long. It raises the mounting tab WAY off the plastic. About the thickness of a second, stacked mounting tab (for the rear rack)! It even makes the grab rails a little uneven.
I bet they started shipping the side racks with a "too thick" spacer to discourage people from stacking the mounting tabs! A "third" thickness of mounting tab would definitely interfere with the seat, but if the spacer were thinner by the thickness of one mounting tab, as I think it should be, then the mounting tab of the rear rack would be in the exact same position (height) as is the side rack alone now!
I sent Rich at Twisted Throttle a link to this thread. It will be interesting to see what they think.
Thanks all! This helps me make my decision to buy the rear rack and experiment, if necessary. (I'm thinking a stack of washers less high than the thickness of the supplied spacer should do the trick. Same bolts, even!)
1 - 20 of 35 Posts
