1 - 3 of 3 Posts
Does the long rod came with that for the bottom mount, has to be treaded over the bike body? in another word , do i have to take the pin out so that to treat this new (longer) one over? But i have to tough time to unbold it and take it out to begin with. :confused:Any suggestion , Help?
Wongkong, the long rod I believe is the bolt that replaces the bottom engine mount bolt. You must remove the lower engine mount bolt and substitute the long bolt along with the proper spacers in the proper order. The front sprocket cover must come off to do this.
You need proper tools for this job. Get some help and read instructions. Good luck.
1 - 3 of 3 Posts
