1 - 4 of 4 Posts
I did a valve clearance check and found them to be in spec and within .001. This is at 10.7k miles. So with the time I saved, I thought I'd try modding the sub-throttle plates. Seems like a lot of people have taken them out and then put them back in, on many different bikes. I trimmed 4mm off the radius of each plate and tapered that radius so the area across the shaft wasn't changed. I can tell you that 4mm isn't too far as there is no bogging or hesitation that I noticed. 3mm would definitely be safe.
Is there a benefit? I can say that it definitely didn't hurt anything, and even though I perceive it to accelerate harder, I have no way of quantifying that. At least I don't have to pull it back apart to put them back in! It's an easy mod to do if you have the airbox off, so give it a shot.
Heat the single screw with a soldering iron for a minute to loosen up any thread sealant (seems like it was only on 1 screw), then back out the screw. Mod the plate; I used a good pair of scissors that cut the 1mm aluminum with ease, then stuck them together and filed them to match. Blue loctite on the screw and you're done.
Could you explain me the benefit of remove those plates?
I heard that it improves the middle range acceleration... I heard too that they are there to smooth acceleration on that range... What is the truth?
I would like to hear those good-technical explanations from our friend Invader... if possible :rolleyes:
Thank you!!!
1 - 4 of 4 Posts
