1 - 1 of 1 Posts
Just a FYI early on the How To Forum was my Idea, implemented by me and a large number of posts and threads have resulted in that forum by me. It was pointed out that there are many stuck threads and it is hard to wade through all these to find the active threads, in some ways the stuck thread eliminates numerous threads being started such as the oil or tire threads. I have copied all the stuck thread links into one thread. Unless someone request otherwise, as soon as I extract any valuable info, I will remove that link. If several someone's want's one of those threads stuck again, let me know. Yes it is a huge inconvenience to scroll down , however using TapaTalk I can see it, so a large number log in that way. JMHO
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/218691-ecus-flashing-tuning-versys-650-complete.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/218675-chain-alignment-anomaly.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/218337-switching-synthetic-oil.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/211513-tools-versys-ownership.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/75034-2015-accessory-sockets.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/8918-chain-slack-adjustment.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/217907-clutch-lever-went-clunk-all-sudden-now-1-2-way-engaged.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/4958-r1-shock-fitted-need-spring-source.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/133690-drips-droops-other-disasters.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/217579-versys-stator-questions.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/217543-radiator-coolant-flush.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/18741-fuzeblock-installation-under-left-fairing.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/217349-2009-650-stator.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/216767-octane-rating-do-you-use-your-versys.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/118866-engine-not-firing.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/16079-coolant-reservoir-noise.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/211065-tps-sensor-adjustment-2016-versys-650-a.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/216531-gen-3-throttle-body-sync-questions.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/216783-rear-tire-tiny-pinhole.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/216627-quick-break-question.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/211705-questions-about-new-tires.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/212097-28-000-mile-valve-questions-c-w-photos.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/131474-another-charging-issue-thread.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/120866-diy-front-rear-wheel-removal-how-pics.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/210753-radiator-fan-motor-d-i-y-bearing-replacement.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/208273-electrical-gremlin-strangest-order.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/210449-gen-3-mystery-connection.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/205889-changing-tires.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/207657-throttle-free-play-adjuster.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/25802-centre-stand.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/119994-suspension-settings.html
https://www.kawasakiversys.com/forums/170-technical-discussion-v-650/132306-12-2016-stator-failure-posts-posts-related-those-converted-series-regulator.html
1 - 1 of 1 Posts
