1 - 15 of 15 Posts
Hey folks, my last V came with a stebel, and the one I have now has a Fiamm. Is the Fiamm stock? If not, should the Stebel be plug and play with the Fiamm set up, or would I need to rewire as per the Stebel instructions? Any thoughts would be appreciated.
Thanks in advance.
If you have Fiamms you might have a relay, i put one in on a Fiamm install. Check for a relay and the relay rating.
No. Stock is a little horn that sounds like a (VERY small) mouse-in-heat when you press the horn button....
:rolleyes:
Hey...I LIKE my little mouse.. :p
On an earlier "horn" thread, someone posted that the stocker puts out a LOT more noise IF you add a relay so it gets FULL power!
For pricing I recently found the best deal is from Biker Hypatia for both the horn and the plug and play relay.
Thanks, got it all sorted and on the bike. Pain in the parts trying to find a place to mount it, but all good now.
I got a compact air horn at northern tool. for around $35. most auto stores carry a compact air horn for $40.
1 - 15 of 15 Posts
