Stator coating - is it necessary?
8.5K views 21 replies 10 participants last post by  onewizard
Reactions: JT in GA
2010 Mk2 stator burnt out and I need to replace it
There was an option to rewind it for £200 or get a new one for £140. I went with buying a new one. To my surprise when I got one that it seems it has no coating on the coils. I am sure the current burn out one has some coating on top of the coils
So I am slightly concerned if I am not wasting my time and effort on my new purchase
I also seem to have overspent it - on US ebay basically exactly looking stators is going for three times less but... options are limited here in uk
For reference, I was looking at something more of Rebuild Your Bike's Expensive Stator
First, that stator is not equal to OEM, pay attention. Note at the very top of the stator, a rivet exists, directly above you see 3 magnet wires passing into a piece of black sleeving. That is the Y or Star connection ( 60% of the copper of OEM)
OEM is Delta wound.
The only place to buy equal to OEM is Electrosport.
My thread Stator / OEM vs Rick's Stator/ China Star...
is copied below
Discussion Starter · #26 · Aug 5, 2019 (Edited)
ElectroSport Delta Wound / Info
This was sent to me as a Email message. My comment is the OEM states it as 330 Watts. At one time I considered rewinding a core I have, one consideration was to drop some turns per phase, which would produce a lower impedance and also a lower output voltage, in turn this would produce a higher current. It is hard to say if ElectroSport did this, also I looked at increasing the wire gauge to a single 14 gauge wire Star wound, or a 17 gauge Delta wound ,this would be extremely difficult to hand wind, and there is insufficient room for 17 gauge unless you drop turns Delta wound. Presently the OEM is one 18 gauge wire per phase.
I also have a link and last time I checked it was around $140 USD
https://www.electrosport.com/collec.../products/esg638-stator-kawasaki-zx-6r-zx-6rr
This is from a PM sent to me;
date: Aug 5, 2019, 9:24 AM
subject: Re: Versys 650 stator tech question
ESG638 is delta wound. The power output is 330w by out measurement, the OEM was 300w, so ESG638 is about 10% more powerful.
The reg/rect we sell for this bike, ESR444, is a shunt unit like OEM.
Kyle Wood - Sales Manager
Procom Engineering / ElectroSport
21 Brookline, Aliso Viejo, CA 92656
PH: (949) 305-4200
  • Helpful
Reactions: JT in GA
As to the lack, of a coating, wrong again, I worked in a motorshop for 9 years, the varnish or encapsulation prevents the magnet wire from vibrating, that magnet wire has a .003 of a inch coating, without the coating it will fail prematurely
If you get bored you can read the following by me:
latest winding info;
Reactions: JT in GA
Doesn't the stator get splash with oil?
I would think you need it varnish coated so particles in oil don't over time wear down the thin layer of coating on the wires and short things.
Maybe you can find a way to claim item is junk and return to seller for some credit.
First I am rarely on this forum due to many of my threads being partially duplicate and many valuable threads are MIA.
So I will explain something in this thread ( I am very sure if you spent 15 or 20 hours reading my posts, eventually you would find a thread with a post by me explaining it-And THAT 15 or 20 hours is also the problem I am having and administration turned me down to be able to correct it-I am at a point where I don't give a SH--T )
Explanation of magnet wire various classes of insulation, varnish dipped; epoxy coated; encapsulated, or nothing.
Induction; counter EMF; permanent magnetic field; time constant; applied force equal to and opposite that of the applied force -- all of these terms and words are related to both AC and DC motors and alternators/generators.
I am sure some of you have seen someone using a portable stick welder with long cables, every so often you see these cables jump-generally this happens when the person welding stricks the arc. The reason is the inrush current striking the arc produces a VERY STRONG MAGNETIC FIELD ( the strength of the magnetic field around each cable is directly proportional to the current through this cable)
Next , some of you have been around distribution transformers in small businesses, you may have noticed a loud humming and possibly felt a small vibration, that is in some cases the laminations ( LOOSE laminations, they are stacked and many times these laminations are already coated before the winding is installed) vibrating from the alternation 60 hertz frequency.
So what happens is in our permanent magnet rotor alternator, that rotor is moving a north and south magnetic field across the winding of our stator. This magnetic field produces a voltage and when we have current flow we get what is called counter EMF, equal to and opposite that of the applied force. And THAT IS THE PROBLEM, the magnet wire is pulled and pushed alternately each time the north or south pole crosses the winding. If you don't coat the winding with varnish or epoxy or encapsulate it, and LOOSE magnet wires will vibrate, this vibration will wear the .003 of a inch coating off the magnet wire--part of this problem is early stators brought the delta crossover connections from the poles across a winding from the back, weventually you got a line to phase short and joined the BURNT STATOR CLUB .
I helped a member here rewind a stator-hand wound and in all honesty ( with 9 years of me working in a motorshop - probably better than I could have done)-this guy was exceptional and he did coat the winding in the end and it was Delta wound! @fuse_X
Pretty NICE having "onewizard" back in the fold, isn't it...?
(y)(y)(y)(y)
:cool:
Honestly, Ed-"And THAT 15 or 20 hours is also the problem I am having and administration turned me down to be able to correct it-I am at a point where I don't give a SH--T ) "
I
may not post again for another 8 months and the longer I am away, the harder it is to come back here. Until management reaches out to me I see no solution. :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: Made myself laugh-the chances of management reaching out to me--- is like me giving Putin a call and asking him to stop the war:eek::ROFLMAO:
Stator coating can be beneficial for protecting the windings from moisture, dust, and other contaminants, especially in harsh environments. It helps improve insulation resistance and prevents corrosion, ultimately extending the lifespan of the stator. Whether it's necessary depends on factors like the operating conditions and the level of protection required. In some cases, the stator may already come with a factory-applied coating that provides sufficient protection. It's essential to consider the specific application and consult with professionals to determine if stator coating is necessary for your situation.
You sound like you are either in the industry or copied this from some web site.
I had a post I used every so often but hard to find, the comment was looking for a service manual. It would apply to your post in this thread. I would suggest using my link here and introduce yourself . I would be REALLY interested if this was YOUR knowledge. As very few fully understand what you just posted-
FYI read the bottom of each of my posts. To be clear, I rewound motors, changed windings from star to delta, some really special stuff, including R&D .
First you should post in https://www.kawasakiversys.com/forums/🖐new-member-introductions.5/
Please read the posts above-no link available directly from this site. You need many posts to allow private messaging. Asking in your first post for a PDF service manual, is like going to a grand opening of a bakery, where free donuts are offered, BUT -you won't be coming back and buying $$$ once they open for business.
What product to coat these cheap Chinese? I am looking now as I just bought one.
Take a close up on both sides of the stator and post it. It isn't the coating that is the problem, it is the wire size and 66% of OEM copper, and the fact it is Y connected instead of Delta.
A better investment would be switching to a series regulator!
I might also add, keeping your oil level just above the high mark, as the oil is what cools the stator, this was proven on a UK Versys site years ago.
