1 - 13 of 13 Posts
MY 09 Versys use to start in 1st gear with kick-stand up. Couple days ago, it wouldn't start unless kick-stand was up and in neutral. Removed switch and check operation and connections. Switch is working ok. Every once in awhile when i start engine and switch to first gear from neutral it dies. Any suggestions?
If you start it in neutral then shift to first and it dies, it sounds like the sensor that detects if the kickstand is down. I know you said you checked the switch, but how did you confirm that it's working okay?
I checked switch with volt ohm meter. I suspect intermittent wire connection on kick-stand switch. I remove the switch which consist of wiring harness and physical switch. Everything is working ok according to the meter. The funny thing about this whole mess it that if I push and hold start button for 5-6 seconds, sometimes it starts in first gear. I might order a new kick-stand switch.
I had similar issues w/ my '08. Sprayed that switch coming off the front of the clutch-lever w/ WD40, let it 'soak-in'. Fixed my problem.
Mine is a 09 and never had a problem with kick stand switch . Use some contact spay to clean them and you should be good ...hope it works for you.
I had this problem on another bike and the solution was exactly the same except that I used Radio Shack contact cleaner. Opened up the right had clam shell of switches, sprayed the kill switch good (might have spray all switches in it but don't remember) , flicked the kill switch back and forth an number of times, and never had another problem with it.
ok...explain where you sprayed it .....thanks. this is driving me crazy!!!
I just disconnected the plug from the switch and sprayed the WD40 BOTH ways, near as I can remember....
I did the same thing with either WD or some type of electrical contact spray and it corrected the problem. I am talking about the connection that is up on the handlebar, having taken it apart, spraying, reconnecting, and voila, it worked.
1 - 13 of 13 Posts
