1 - 20 of 21 Posts
Just got my riser and peg lowering blocks from Motowerk in record time. And I thought Amazon Prime was fast. :)
A quick question to those riders who like to occasionally stand on their pegs, like I do, and are using the Motowerk peg lowering blocks:
do you feel confident standing on pegs that are extended via the Motowerk blocks?
TIA
i dont have there peg lowering blocks but my bike has there rear suspension lowering block and iit looks to be milled from the same metle and i hop off curbs and it hasnt snapped so i think you'll be fine (as long as you weigh less then an 08 650 versys)
Thank you for that vote of confidence.
I had Fastway pegs on my last bike and never used extenders. Standing felt VERY comfortable and stable.
Gonna put either Fastway or TT/SW-Motech ones on the Versys.
Thanks again.
Thanks again.
another good idea is google reviews about them or claims against them.... never know but thats just what i do
Don't overtighten peg on it.
Be sure you don't tighten them too much. After two thousand miles, this happened the other day.
I now have a Yamaha dirt bike peg there. Ha ha.
I'll be ordering pegs this week and will slap the blocks back on!
Your weakest point is the left cover/footpeg holder... I made my own out of steel after it broke from a tip over in the bush.
http://www.kawasakiversys.com/forums/showthread.php?p=298722
Wow!
I'll assume that that was a stock peg.
Just found out that they don't make a Fastway peg for the Versys.
So it looks like the TT/SW-Motech one will have to be it.
Thanks.
wrong...Fastways fit the Versys just fine, been using several models of Fastways for years and tens of thousands of miles. very high quality footrests, also somewhat adjustable via the threaded insert at base.
Fastways on Versys, also custom oversize folding tip on brake...
Hmm! That's interesting. Just got this email from a rep of theirs a couple of hours ago, though:
"Hi Peter,
Unfortunately, we do not offer a peg for the Versys.
I hope the fact that your eyes are in good shape is a adequate consolation prize for you.
All the best,
Robin
Robin Warner | Pro Moto Billet & Fastway Performance
11461 Lone Star Road | Nampa, Idaho 83651
phone: (866) or (208) 466-4762 x236 | skype: robin_warner
www.ProMotoBillet.com | [email protected]"
Why would Miss Warner say what she said then?
I have the Motowerks bike lowering link and footpeg lowering links. I stand on them with no issues. I had seen the pictures of the peg that broke due to overtightening. From Lowes I bought nylon spacers that were slightly too large for gap on pegs. Sanded down to fit, then installed with Factory pegs. Somewhere on here is article about dirt bike foot pegs that fit versys. I picked up a pair on ebay for around $20. did same thing with spacer and I like these much better than factory. wider and more comfortable. Only Issue I have is I recently noticed the left foot peg rocks slightly. Found it is the entire assembly. I will have to take bracket off to tighten Hex mounting bolt on back side.
she wasn't aware of the full range of models that the Fastways would fit...perfectly, i would add. feel free to forward a copy of the photo of their Evolution footrests mounted on the Versys.
remember, the Versys uses a 12mm pin, so you don't want a set for a moto that uses a 10mm footrest pin, also very common. if you happen on a used 10mm set, you can either bore them very carefully, or purchase a 12mm fit kit. the mounting collar is removable since it can be reversed for a small height adjustment, in addition to the camber adjustment.
the Fastways are stainless steel, they ain't going to break.
This is her reply to your comment above, JD:
"Peter,
We don't have it as an official fitment for this bike, meaning we have never installed our peg on this year, make and model. Can you get the part number that this person installed on this his bike? That would be great start.
Obviously, I would love for you to get back on Fastway pegs!.
R
I stand on mine all the time, I suggest using nyloc nuts so as to not have them come loose because I didn't want to over tighten them. Or it wouldn't be hard to cut a piece of pipe to fit in there so you cannot over tighten.
I'm a big guy
I do sometime stand on my peg and actually, it's pretty often the way I hop on my bike
I have the speedy lowering footpeg block
I was carefull not to overtight the peg (as per Invader tip)
But in reality, my biggest concern is the versys plate on wich the block/peg attach to the bike (read Invader tip further up)
I have no fear of the block breaking, but the plate is another storie ... So far so good !
LOP
At the time i weighed over 300l bs before gear I had Motowerks peg lowering blocks and i stood on my pegs all the time as you can see in this video I'm right in front of the camera.http://youtu.be/wy5oiDC84as?t=11m46s
I read somewhere that the Motowerks lowering pegs can support 200kg each.
Don't quote me as I do have a tendency to drink when not riding.
Motowerk's lowering blocks are solid for sure. They'll never break. They do add more leverage and strain on the cast aluminum side frame covers/footpeg holders, particularly the left one which is more susceptible to breaking and which also holds your shifter's main pivot.
Cool vid. Impressive skills. Good taste in music too. Nice trifecta. :)
That video is from a guy on a Harley V-Rod. Earlier he said the Versys couldn't keep up with him so if you watch the whole video you can see me leaving him in the dust and having to pull over for him twice...:D:D
TIA
I have run foot-pegs from a Suzuki DR650 on both my KLR and then on the GREEN HORNET, and when I wanted them on BIG RED I bought a set of Ebay ones for about $15. The DR's use 10mm bolts, and I've used the 'pegs w/ 10mm bolts (actually 3/8 UNC w/ a nylock nut) each time (rather than drilling them out to 12mm), and, after LOTS of standing I've NOT had any problems (I weigh about 200 lbs 'geared-up'). Also I have Motowerk foot-peg lowering blocks on both Vs.
1 - 20 of 21 Posts
