1 - 20 of 32 Posts
Just completed installing Speedy's lowering kit. Didn't take very long, thanks to Speedy's clear and concise instructions. Have worked on bikes (long time ago) and cars alot and had all the tools so it went smoothly and quickly. The V doesn't feel nearly as top heavy now, but that could be my imagination.
I think it helps the handling and tames the shock a bit. Also a really well turned out piece of kit! Glad it went well for you and enjoy the bike!
I should probably taken some but I didn't, sorry.
Speedy's lowering kit increases shock compression to suspension travel ratio a bit, which stiffens the ride and reduces suspension travel slightly (also maintains tire to fender clearance with fully compressed rear suspension). You may want to try a notch lower on spring preload.
Center of gravity is in fact lowered... No, I haven't lowered mine.
Not sure if Speedy's instructions mention to check your chain tension!!
Mine was very tight after the lower. Had to loosen it quite a bit to get the proper tension.
:cheers:
I lowered mine even though I didn't need to. I could flat foot it before, I just got tired of throwing my leg over a tall bike which will never be ridden off road. The bike feels better in the twisties for sure even with the numb feeling stock tires. I would highly recommend this mod to anyone who desires a more normal feeling bike. Looks wise, you would need to stand it next to a non-modded V to tell the difference.
:cheers:
Thanks Capn Kirk, I just checked and it's fine. Wouldn't have thought to check though, and no, Speedy's instructions don't mention it.
I really love the feel of the bike lowered, plus it was pretty hard to get on and off with the luggage installed.
good morning,
don't forget the front forks.....see other post about lowering the bike...congrats....:clap:
good luck,
FREE TEXAS,
bluebonnet2
:cheers:
It was adjusted too tight to begin with. The lowering kit doesn't change the distance between the sprockets, it just lowers the ride height and you were in a different part of the swingarm range. What DOES change is the trail, which influences how the bike turns in on a corner. It will turn in less easy unless you lower the front an equal amount.
My chain tightened after lowering the bike and it was too loose to begin with. The swingarm pivot point does not center on the countershaft.
That's right, Blipco... Chain tension should be checked with rear suspension fully extended. Measured chain slack is reduced as suspension compresses, or with lowering kit or shorter shock. Chain is tightest at just over middle of suspension travel range.
Therefore, proper measured chain slack with lowered suspension is slightly less than stock even when measured with suspension fully extended as it should, because suspension can no longer be extended to stock specs.
Discussion Starter #14
Thanks for the advice bluebonnet, I lowered it to the rough area per Speedy's directions.
I'm curious as to how you raised the rear of the bike so the swing arm would extend and still kept it stable. I know Speedy mentions a bike lift, or two jacks or paint buckets but I'm not certain about any of those without further instructions (for a dummy). :eek:
Discussion Starter #16
Arion,
I put a jack stand under right foot peg, lifted left side by tilting it on the right stand and slid second stand under left side. It's not too hard, just make sure first stand doesn't slip (a helper is good).
Arion,
Thanks, I appreciate the information. Sounds simple and straight forward. And I'm a great believer in helpers, if for no other reason that it's something soft for the bike to fall on and cushion the blow (to the bike). :D
Dear Invader,
I also think the kit does compress the suspension, making it stiffer for the ride. What setup you recommend for the preload, and the damper?
I just had the lowering kit installed, and the flatfoot added along with shortening the kickstand.
Already the bike feels better. I'm more stable at stops and the riding position is more comfortable. I can sit at a stop with both feet flat on the ground and my knees bent.
The Versys seat height is quite high at 33 inches; Speedy's lowering link drops the rear suspension by 1.8 inches and makes the seat the perfect height for me.
I'd add that shortening the kickstand is probably going to be necessary for most bikes once the lowering link is added. I did not lower the front and I'd think that would make even more of a difference.
All i did was to keep it on the side stand,slackened the nuts first,used a car jack with a 2 ft length of wood under the rear subframe.jacked it up just enough so the the bolts turned easily.Took me about 15mins start to finish.
I also lowered the forks by 2 inches otherwise it would affect the handling.
1 - 20 of 32 Posts
