1 - 20 of 20 Posts
I just installed speedy's anti vib riser
My questions is
With every thing installed and tight using locktite. How much movement is normal when rocking the bars left and right?
I just tried installing speedy's anti vib riser. I bought it second hand so have no instructions.
I had to seperate the two hafls in order to be able to secure the bottom half to the stock cast riser using the suplied countersunk screws. I noticed when I split the two halfs that the four screws that hold the top and bottom half together thred into the bottom half then have nuts on the underside of the bottom half. these nuts all came off on re install. I disassembled again and crazy glued the nuts back on.
On the second install attempt I know that at least one nut broke free again but i believe it is still on the screw.
My questions are
1. how critical are these nuts?
2. With every thing installed and tight using locktite. How much movement is normal when rocking the bars left and right?
3. If it is crucial for the nuts all to be on and tightened right up. How did you do it?
You need to e-mail speedy........https://www.motowerk.com/Contact_Us.html
anti vib riser
Thanks for the email link. I have everything secure now and founfd the instructions on his sight but will email him anyway. The only real question I have now is concerning any movement in the bars when rocking them left and right.
Any response would be appreciated.
There is a gap and the bars do rock back and forth. I will take photos of mine tomorrow and post for you. Its to dark now.
Joseph
Thank you. I will check for your pictures tomorrow. I have also emailed speedy for input.
Good Deal.. Its sounds like your okay but speedy will know for sure.:goodluck:
Thanks very much. The video shows the same amount of movement that I am seeing. Any chance you could tell me the gap measurement when not flexing, just sitting static?
any chance you were able to measure the gap for me?
It'll be tomorrow. I had to take my buddy to have his bandages changed. So i was tied up for awhile.
Thanks, I've been considering this as one of the things I will do to my bike when our money situation improves.
It doesn't affect the bike in anyway but gets rid of most of the vibes. I'm in the twisty stuff all the time and no issues. :cheers:
Discussion Starter #19
Got it all back together and went for a ride. Definately has reduced vibrations. I can actualy now see something in the mirrors.
Weljo, thanks for your input with the measurements.
Anytime!! :cheers:
1 - 20 of 20 Posts
