1 - 9 of 9 Posts
Any advice on soft saddle bags? looking for something waterproof that can hold a helmet if need be. Also looking to mount some fog lights, any advice on witch ones? Also the best place to mount them.....Thanks.
I have, or have had, FOUR sets of soft bags. Been to Alaska 3 times with various sets, and for water-proofing, I stick 2 garbage bags (1 inside the other) in each one with my stuff inside. I've been wet, but my stuff's stayed dry!
Two words. Ziploc bags.
The heavy duty freezer bags will keep things dry unless you go under water.
+1
Take a few extra to hold the smelly sweaty clothes from contaminating your clean clothes. They make good compression sacks too. Stuff clothes in, roll to compress and force out the air - zip closed. I've used a lot of these in the past and each bag holds a set of clothes. Unzip - change and the dirty clothes go in. Also work well for food & snacks. Easier to pack than boxes and food stays fresher longer.
+1
You can get them online in big (3 gal) x-large (10 gal) and xx-large (20 gal).
Hi
On my 2009, I have
VisionX LED lights (which seem the same as Denali lights)
1 of NSW.08.004.10100.B SW-Motech Auxiliary Light Mount (Kawasaki Versys, '07-'09) $55.00 from Twisted Throttle
2 of Vision X XIL-S1102 Solstice 2" Square Spot Beam Solo LED Pod Light
http://www.tontodonato.com/images/Versys/Lights_640.jpg
Daytime video of turning them on:
1 - 9 of 9 Posts
