1 - 5 of 5 Posts
I've ordered smoked indicator glass
Why ?? because the taillight is smoke too.
Only € 8,87 on aliexpress dot com
Heads Up ! they drilled the holes too small.
The first set cracked while turning the screw in.
Got a refund and ordered the 2nd set, first drilled the hole bigger.
It is 2,4mm
I drilled 3mm ... $hit... too big
best diameter is 2,8mm.
I like the result.
First picture : smoke on the left and clear on the right
Why ?? because the taillight is smoke too....
I have to make a comment that will be perceived as being negative - WHY would anyone, for ANY reason, do an alteration to lights on a vehicle that make it LESS visible?
Discussion Starter · #5 ·
Because it is now matching the taillight.
I drove behind her today, can't say it's on the same level, but it it still clearly visable
1 - 5 of 5 Posts
