1 - 20 of 32 Posts
Good day all. I am about to purchase a skid plate.
SW Motech, Hepco & Becker, Happy Trail, Adrenaline?, ???, Other one that won't return my e-mail.
I am quite disappointed with the complete lack of choices for the Versys. I really don't care what the thing looks like, and I'm not scared of a little fab work, but I have the following requirements. It must be mounted to the frame or heavy aluminium casting. This eliminates the SW and the H & B. It must be flat on the bottom so I can use a traditional lift to lift both wheels of the ground. It must have access to the oil filter.
Really, this is not a lot to ask.
I have read everything on this forum about this subject, and from what I have read, HT is one of the worst companies to deal with. For my requirements, HT is the closest to my requirements.
My mouse is poised over the PAY button on the HT website... Any last minute ideas?:feedback:
I had Happy Trails skid on my 2008, and now i got SW-motech on my 2012.
both skid plates are good, but in my opinion SW motech is way better.
let me explain and tell you some of my thoughts:
with Happy Trails you get horrible customer service, you will need to drill holes on the plates that are kinda specific to your bikes fitment, and if you get a newer bike, like i did, it will be a problem to fit it to the new one. Also it does not protect the sides of the bike properly, so gravel roads will destroy the stock plastic easily. clearance is reduced by a lot if you are using happy trails also. and access to filter is by removing 4 bolts.
SW-motech, nice sturdy peace of metal. protects the sides well, fits on rubber gromets, so less noice and less vibes on freeway. access to filter is about the same, although you can drain the oil without removing it. I use car jack with wooden block to lift the bike and it works like a charm. And estetics is better with the SWM one.
hope it helps
I just had a thought for anyone out there who has the ability to develope a Vee skid plate, why not integrate a center stand into it. The center stand issue with the Vee is a lack of mounting points, wouldn't the rear or bottom of a skid plate provide a surface to mount a center stand to? I think the first skid plate manufacturer to produce a skid plate with the option of a center stand would be a huge hit.
Quote: twowheeladdict - Why does a street bike need a skid plate?
Quote: twowheeladdict - So, you saying I need to add skid plates to all my street bikes? I thought they were only for off road riding where you know you are going to hop logs and rocks.
No, Nobody is saying anything. Nobody is forcing you do do anything. Just like nobody can prevent me buying bottom protection for my bike that I feel is necessary. Unhelpfull.
_______________________________________________________________
Quote: ADV.Russian - I use car jack with wooden block to lift the bike and it works like a charm.
Interesting. Never thought of that. I guess I thought it would be necessary to be flat to use my ATV lift. Do you think it is possible to shape a couple of blocks (V Shape) to fit under the SW plate to lift the bike off the ground? I use this ATV lift and a couple of blocks for my CR250 and it works pretty slick. Anybody Try this?
i use mine with the flat one, and it works. i guess has something to do with the balance of the bike.
I had to twist, grind and reweld Happy Trails skid plate tubing and mounts to fit properly, and I replaced the 2 Mickey Mouse plates for larger and stronger custom fitted ones. It sits close to header collector, with minimal loss in ground clearance. I have good oil drain plug access, and it's just sturdy enough to support Versys with both wheels off the ground... Others who have just slapped it on as is had very poor access to drain plug.
Interesting that you equate need with force. Asking if I need something doesn't equate to force. Must be one of those master/servant things.
I guess what I should have asked is what is the purpose of putting a skid plate on a street bike.
Don't tell me you think the Versys is anything but a street bike. My 77 Honda 550 four Supersport street bike was more off road friendly than the Versys is IMO.
:D
Don't want to hit bottom! :eek:
Thread about a guy on this forum that hit the bottom of the V. Bad damage! :eek:
If it's the thread I'm thinking of, that bike had the Algard attached via the oil pan. To be honest, I don't know if any of the pans will truly protect against a solid object (eg half-buried rock or edge of a deep pothole). They are designed to deflect loose objects, such as small rocks thrown up from the front wheel.
That said, I have the Algard attached via the exhaust pipe. I can ride a (loud) bike with a cracked pipe... it's harder to ride a bike with a cracked oil pan.
Dave
My KLR had an aluminum skid-plate that showed a fairly wide line down the center from little rocks and stuff kicked up from the front wheel.
Seems as good a reason for one (skid-plate) as any other....
Good point, Eddie. My skidplate's front checkered aluminum plate is permanently pitted near the middle from top to bottom. Great protection for exhaust header, oil filter, and crankcase. It also perfectly protects bottom at exhaust collector when slamming it down on humps and stumps while on gnarly offroad stints.
I've always had a Fenda Extenda, and a radiator guard.
Discussion Starter #20
twowheeladdict - Interesting that you equate need with force. Asking if I need something doesn't equate to force. Must be one of those master/servant things.
twowheeladdict - I guess what I should have asked is what is the purpose of putting a skid plate on a street bike.
twowheeladdict - Don't tell me you think the Versys is anything but a street bike. My 77 Honda 550 four Supersport street bike was more off road friendly than the Versys is IMO.
Master/Servant things? People tell me I NEED house insurance. For good reason. I am, in a way, FORCED to buy it. Ouch, Master/Servant things... Try saying that to my face.
I have owned and still own "true" DS bikes. I have raced motocross since I was 8 (I still have the X Rays to prove it). I get your point. We ALL get your point. A 200 pound CRF with it's 12+ inches of wheel travel is better off-road than a 450 pound Versys with 5 inches of wheel travel. Duhhhh. Like many people here on this forum, I tend to take my Versys down the odd "Dirt Road" when I'm out exploring. Those of "us" that have driven down a dirt road can tell you, occasionally, you come across a pothole, loose stone or a root. Sometimes your front wheel can spin up a stone toward the exhaust and oil filter. No, I would never hinder (in any way) the Versys' on road ability. In fact, I would never replace the corner carving 17 inch front wheel in favor of a 19 incher, because I am not willing to give up anything on the road. A one pound skid plate would have little affect on "on road" handling.
Please stay off this thread. Nobody is interested in how poorly you think the versys is off-road, compared to your old 550. Your comparison is foolish.
To everybody else, can you still get the Alguard Plate? I am not getting any response from the e-mail address I have.
1 - 20 of 32 Posts
