Hopefully this is a simple question with a simple answer as I don't want to invest a lot of time or money. While this isn't about my Versys specifically it's related as I had moved my gps to my Versys when I bought it last year. I had planned on selling my Ninja 650 but she is still around. I want to get a phone ram mount for it but was wondering, what is the simplest way to connect a usb power cord to the phone from the bike. The Ninja is virtually bone stock and the only electrical mod is a pigtail coming off the battery leads for winter storage. Is there a cable I can run from the pigtail to the phone? Would I need some sort of fuse? Thanks in advance if anyone can help.
I bought a voltage meter that plugs into the SAE pigtail that includes 2 USB plug-ins.
MICTUNING SAE to USB Cable Adapter with Blue Voltmeter 4.2A Dual USB Charger for Motorcycle for Smart Phone Tablet GPS https://www.amazon.com/dp/B0761KJSDV?ref=yo_pop_ma_swf
Stuck one Velcro dot on the back of the meter and one on the frame of the bike to keep it from flopping around.
Sent from my XT1575 using Tapatalk
This looks good too. Thank you!
I usually mount a USB socket (you can drill holes, or use double stick tape and mount a small flat one under the dash area) and wire it unto something up front, like the head light or front marker light. On my Versys, I installed the accessory relay (I have one for sale in the classifieds) and then wired everything into that. Then I use a RAM X-mount to hold the phone.
12V USB adapters:
https://www.amazon.com/Agile-Shop-Converter-Module-convert-Adapter/dp/B01N4H5PNO
https://www.amazon.com/FICBOX-Socket-Waterproof-Charger-Motorcycle/dp/B01F2WXUFW
https://www.amazon.com/VANJING-Waterproof-Charger-Adapter-Motorcycle/dp/B01N5ATKQ0
RAM X-mount:
https://www.amazon.com/Cradle-Holder-Universal-X-Grip-Cellphone/dp/B0055PH0XA
I used a ram ball on my SWMotech GPS mount, but there are many different ways to mount one.
