Tried twice before to mount the Stebel. Its just to big to mount on the Versys 1000 as a full unit. So separated the compressor from the resonator. Fitted a brass fitting got two clamps and some tubing.Mounted the compressor to the stock horn mount and the resonator next to it. The front fairing wouldn't fit so took the stock horn mount off zipped tied the compressor to the lower fairing bracket and the only way to get the fairing on with the resonator was to zip tie it to the compressor so its beneath the compressor....Success. Didn't take any photos of it mounted but what the heck it works and its loud. BTW i broke the excess plastic off the resonator where the compressor was held. Some folks use a dremel i just used some hand tree pruners to cut it off
P1010734 by weljo2001, on Flickr
P1010735 by weljo2001, on Flickr
P1010736 by weljo2001, on Flickr
P1010737 by weljo2001, on Flickr
P1010738 by weljo2001, on Flickr
P1010739 by weljo2001, on Flickr
P1010741 by weljo2001, on Flickr
Discussion Starter #2 (Edited)
I've never even seen a V 1000 so I'm guessing there is no room under the side fairings.
Not for the stebel... But you can get a Denali Split Sound Bomb that will fit under 2 of the fairings.
Obviously much different than the 15' V 650................I put a WOLO (same size/shape as the Stebel) under the left side fairing and had plenty of room.
