1 - 20 of 22 Posts
I've read a lot of reviews of the standard seat from SC, but would like a consensus on the low version. Those who have sampled it, how does the height compared w/ the factory seat? I've read where their "standard" seat is significantly higher than the stock, but nothing regarding the lower version. Also, I know its main objective is to get rid of the dreaded slope, but in lowering by removing padding, what happens to the comfort? I'd also like weights, inseams & builds of reviewers to get an idea if there's a body type more suited to this seat. I'm a skinny 5'-9" w/ a 32" inseam and have lowered the back 1 1/2" via the Speedy link & raised the fork tubes exactly an inch. I would likely request a softer pad due to my weight & wonder if any others have gone that route & how it works.
Thanks,
Jim
Pretty sure he's saying he also would like to see a review of the low version.
+1 is a way of saying "me too - I'm also interested in the answers to all of the questions above".
Alternatively - If I gave it a "likes" vote, that would not convey the same meaning as a "+1", in my mind.
My spare seat is a standard Seat Concepts seat. It sits higher, and it puts my helmet further into the turbulence zone that is coming off of the top of my windscreen. Not good, so I continue to use my Corbin, at this point.
That thought had crossed my mind - makes more sense and makes me a goober for misunderstanding. Thanks for the clarification.
I have a 'low gel' seat I acquired used, I believe it's Seat Concepts or could be other brand. I'm 5'10", 165#, 32" inseam. I found the lower seat changes the ergos a lot, the difference in the seat height is about 1.5" and the difference at the 53-year-old knees is uncomfortable. I did only one ride ~50 miles and swapped the OEM back on. Might be willing to trade the seat for a set of DRZ forks for my wanna-be JDRocks rat bike.
With the OEM seat, I can flat-foot both sides with riding boots on and with Rawkstar's seat riser.
The gel seat was slightly better in terms of ass pain, and admittedly I haven't tried it with the riser block yet (which would restore some of the height back).
I have a set of Motowerk peg lowering blocks to install for more improvement - I'm almost enough with 2" Rox risers to comfortably stand on the pegs without hunching over. The lowered pegs should be perfect.
If you wants pics, let me know.
I suspect if it's a gel seat, it's likely a factory optional seat. It would be hard to tell by the base in that the Seat Concepts uses a factory pan. If it's not too much trouble - a photo would help determine if it is in fact a Seats Concept.
In any event, thanks for responding.
Has anyone else tried the "Low Seat Concepts Seat" on their V?
I'm thinking that installing foot peg lower-ers would solve the "reduced distance from seat to foot peg - sore knee issue".
My bike came with one, I think it's ok but I also have a Sergeant seat and I like that better. I'll probably list the Seat Concepts Low Seat in the classified forum eventually. I don't find much of a height difference between the two.
Didn't like that Seat Concepts "low" seat? :wink2:
How are you liking that bike?
I went back to a 2014 (Gen II) model.
No, I don't like the Seat Concepts "low" version, either. Better than factory, though.
1st 2014 model..... with Seat Concepts standard seat and lowering knuckle, etc.
Second 2014 model with Seat Concepts standard seat and lowering knuckle, etc.
I'm enjoying it, thanks. Took it on an 1100 mile trip recently, I had a great time. I will post pics on the Member Rides forum eventually.
So here's the pics of the low seat I have:
1) low seat main, just a pic for identification. Came off an 08, and I don't know if the embroidery is OEM or not.
2) low seat underside - if you zoom in there are no extra holes where it would indicate re-upholstery, so might be OEM
3) 2010 OEM and low seat, can't really see the thickness of the seats in comparison, but can see the profile difference
4) OEM measured - sitting roughly level, the grid of tapes shows the height about where my butt sits at 7"
5) low measured, about 5 1/4", but note the profile is very different
6) is just a close-up of the grid
Good luck.
Discussion Starter #15
Discussion Starter #16
Cripe Joe - you don't mess around. I'd say you went above & beyond the call of duty - thank you. I'm not positive, but pretty sure that seat is the factory item. I'll pour over your photos & see if those seats, if they're still available, would be good for me. Again, thanks for your time & effort.
Good luck.
I did spring for the low seat kit from Seat Concepts. If your only aim is to get a lower seat height, it does that, but for me it is not much different in the seating position than the stock. Ass is closer to the ground, but the forward slope still seems to be there. It does put the knees in a more painful position for me after about a 100 mile ride, and because the foam is a bit thinner, I don't think it is going to be that comfortable on an all day ride.
I am going to try raising the front of the seat as mentioned with longer bolts and spacers to see if that helps. Thinking I may just go back to the stock if that doesn't help and maybe reshape the foam on the stock a bit.
I added two layers of carpet pad foam to the front 6-8" of the seat (about 1" sculpted to blend with the seat) and then raised the nose by about 3/4". That in addition to removing about 1 1/2" of foam from the butt area and inserting a 3/4" gel pad makes a pretty comfy seat. I also made some custom highway pegs and the bike is pretty comfy on a 200 mile ride. Haven't done any rides longer just yet.
Seat Concepts/ DIY
I am going to comment on this as I tried out the standard foam seat on a 07, felt it was comfy, no consideration about height was given, if you are height challenged only one way to fix that if you already set your sag front and rear, you need to lower it.
I debated getting this, however with the exchange of our dollar and the extra shipping costs I decided to try my hand at moding it myself, as we have what is called the Foam Store in the city I live in.What I found was purely accidental in moding the seat, I used a small level on the seat, once the fabric was off, it became obvious why so much discomfort, raising the seat cannot correct for the right to left hill located at the front.So to be perfectly blunt, no seat kit is going to give you a lower to the ground than the original seat pan. I did a follow up to my seat mod also my original post with pictures. So if you are comfortable in paying $200 plus for a new covering, go for it. If you plan on doing the seat concepts yourself, my advice is to look in the How To thread, FYI, you are going to need a air stapler and compressed air. My Arrow stapler was on sale for $25, purchased primarily for doing my attic insulation venting install. That Arrow stapler will fire 1/2 staples flush into hardwood, FYI you will need to buy about 110 of the 1/4 stainless staples. If I count the 1000 staples I purchased and the foam, it came to $30, the spray adhesive was a additional $9, of which I used about 1/10 of the can, or about $1 worth.
http://www.kawasakiversys.com/forums/74-how-forum/122466-seat-foam-modifications-diy.html
1 - 20 of 22 Posts
