1 - 20 of 21 Posts
I was working on my Versys. The gas tank bolts were undone but the fuel pump etc. was still connected. I had rotated the tank aside and had it rest on a support next to the bike, as I had often done.
Then I maneuvered the tank a bit carelessly and broke the plastic nipple off of the fuel pump.
That is not a plastic nipple replacement at $6, that is a fuel pump replacement at $220.
Don't be lazy as I was, disconnect your gas tank completely and set it aside.
Alright, brass tube and JB Weld repair it is.
Just know that if my crotch turns into a gasoline-fed fireball, I will hunt you down, find you, and sternly wag my index finger at you.
You can fix that with JB, too!
Sent from my iPad using MO Free
Quote from their order page...
"THIS PLASTEX KIT INCLUDES 5 GRAMS OF WHITE POWDER, 1 LIQUID, 1 APPLICATOR BOTTLE, 1 NEEDLE, 1 MOLDING BAR, 1 VIDEO CD. SMALL PLASTEX WHITE KIT.
THIS KIT IS ENOUGH TO MAKE ONE SMALL TAB OR 3" CRACK REPAIR
All this for $13.95 (plus shipping?) I think not.
Nothing beats JB Weld... and you can pick it up at Walmart or just about anywhere else right down the street... enough to make probably a 24" crack repair.
Just BECAUSE I've seen so many posts on here from guys that do almost anything RATHER than properly removing the tank, I took a few pics last time I removed the tank. To slide that red plastic "U-thingie" outboard to slip off the fuel line, you use a small (1/4"...?) slot screwdriver; slide it into the slot and GENTLY rotate it sideways which pulls the "U-thingie" out of its slot allowing the fuel line to be removed. (Some fuel WILL drip out, so wrap the end of the fuel-line with a cloth.) Here're the pics:
Hope you got it fixed. ANs didn't set yourself on fire!
Gives a new meaning to "Great Balls Of Fire!"
BUT thanks for the heads up...I'll follow the manual as I'm a cheap KLR rider in the Versys game. I know they say "You learn from your mistakes" But I don't want to pay $220.00 per class!
Discussion Starter #18
Thanks Eddie!
Now that I know how easy it really is to remove the fuel tank fully (preventing fireballs gets you intimate with the related motorcycle parts and connections) I will definitely do so.
The "setting the tank aside on a barstool/stack of boxes/whatever" method is certainly not worth the risk.
EDIT:
The JB Weld repair has held so far, no photos yet of Great Balls Of Fire.
I too hope that it lasts longer than 2 years, and I will be inspecting it several times before that much time has elapsed.
That's a spooky looking' 2x4 Eddie...
It's VERY DIFFICULT to find 2x4s that have THAT particular strain of "lumberitis", a form of cancer-of-the-wood....
Eddie is a master cabinet maker, and deals with beautiful wood specimens.
Invader (as usual) has my 'number'...!
:thanx:
Thanks Eddie!
The "setting the tank aside on a barstool/stack of boxes/whatever" method is certainly not worth the risk....
You are VERY welcome! When I joined this "fraternity" back in 2008, a bunch of REALLY GOOD guys helped me out when I posted questions, me being an FNG.
:thanx:
Now as I do things that initially concerned me, I try to help out the other FNGs... ;) ...!
:goodidea:
1 - 20 of 21 Posts
