Have you done an Iron Butt Association or other long distance ride?
  • Yes
    Votes: 16 76.2%
  • No
    Votes: 5 23.8%
  • Total voters
    21
1 - 19 of 19 Posts
Looks pretty boring to me; it's all flat and interstate. Why? Seems to me you could spend the same time in the saddle (maybe less miles) on a route that had some better roads and scenery.
The whole country is basically gentle rolling hills and interstate with isolated patches of awesomeness. And it has to be a thousand miles (plus a little more for odometer accuracy) to be validated by the IBA for a SS1000. This isn't a vacation, I just got back from Colorado for that. This is just a test of man vs. road, machine, and time on some weekend.
I added a link to the IBA website in the first post.
If you really want to test man and machine try Deal's Gap. AKA The Dragon. More fun, better scenery, and it will test your manhood.
Believe it or not, for some riders this is fun. I have done several and will probably do it again soon. There are better roads and scenery but this is just a different kind of adventure on the bike.
Ride safe, stay focused and have fun.
BTW-The Dragon was fun too.
my only comment would be to skip the part along the Lake and replace those miles by going further south on 39, towards Peoria, just to avoid and big city congestion. i did this when i lived in CT. mid-morning, i found myself mired in weekend traffic leaving Boston and headed to Maine. it was painful.
I have not done it yet, but have plans to do one next spring.
If I am not mistaken you had the 43 tooth originally, well this would be a good reason to slap that 43 back on there for straight up cruisin.
I've got the 43 on now, no way I would go that far on the factory 46
I just did a Bun Burner Gold (1500 in 24) this weekend. Minneapolis, MN to Elko, NV.
Turned around and did a leisure ride home for 3100 in 67 hours.
Here is my route. (Gotta update my map!)
If you just want the SS1000 I would suggest a different route. You have too much stuff in that Rockford, Milwaukee, Sheboygan section that can lead to road construction, accidents or other delays. I'd do a circle, Your place -> Fargo -> Minneapolis -> Des Moines. Higher speeds in SD & ND than in WI. Yeah its dull, but success is more likely.
Come start in Minneapolis and I'll do it with you! Don't have time to go to IA and back.
Discussion Starter #14
I could meet in Minneapolis after the first 1/4 on my own, and go 3/4 of the way together, then you would have to ride from around Sioux City (30 miles North of it) back to MN. Possibility I guess.
Oh I only offered to keep you company, some folks feel safer with someone else along. I've got no real need to add another SS1K to my list of rides!
What kind of prep have you done for this? I recommend that folks do a single no-stop fuel tank run. Depending on your mileage that would be 200 miles round trip without a single stop. For you I'd head north or south on I-29, do 100 miles turn around and come back. If you can do it without putting your feet down on land then 1000 miles will be easy, cause all you have to do is that 5 times.
Also more important than how many teeth your sprockets have is do you have a throttle lock? Of all the accessories that I have that is the biggest key to doing the big miles. When your fatigued its really easy to slowly back off the speed an not notice.
Do you have a GPS? If so go by the speed it reports not your speedo. If you don't have a GPS, figure out your speedo error. Mine with a 16/46 setup is high by about 2mph at cruising speed.
On my BBG I literally stopped 4 times for fuel (with the dual tanks I can go more than the 350 miles allowed by the IBA), once to eat and twice to adjust my clothing for local temps. Only other times my feet hit the pavement were for stop lights & construction. They key to these rides is not stopping, it is NOT going fast. The faster I go the more beat up I get per mile, making me more tired, requiring more stops. And on the V my mileage drops off considerably above 85. I only get 39MPG at 90.
Here is an example to illustrate what I mean about speed vs. stops:
77.5 MPH for 1000 miles = 12h54m + 4 stops 15 minutes each = 13h54m
85 mph for 1000 miles = 11h46m + 5 stops 25 minutes each = 13h51m
Add in the fact that you will get a ticket if you try to go 85mph for 1000 miles you can see that managing your stop time is more important.
Now on a SS1K you have lots of slack time, so really its kind of overkill.
Discussion Starter #16
I've done 750, 800, and 850 mile days before on bike's that are straight from the factory, so 1000 on my V will be easy.
List of mods:
43T rear sprocket
kuryakyn grips
throttle boss
bar end weights
NEP throttle lock
kuryakyn forward pegs
RAM GPS mount
TOMTOM GPS
tail bag that is used as a back rest
GIVI touring screen
Lots of different riding clothes/gear
(some other non-relevant mods also)
(soon to be added mods)
PIAA driving lights
Corbin seat
Do you know if I can strap on a 2 gallon fuel tank to my rack? Just the regular red plastic type. My fuel economy seems to wander between 30 and 48, which is a big difference in mileage over a tank, and I don't want to get stranded between town A and town B on a run when time counts.
Your prep looks great! You look good to go.
There are no prohibitions for these kinds of rides against carrying fuel that way (its different for rallies like the IBR or MN1K). However I would advise against carrying that much extra fuel. Those containers are really not safe on a bike and may turn a minor get off into an inferno. Do you really need an extra 80 miles of fuel?
I used to carry an MSR fuel bottle. Just 1L but it was enough to get me to the next gas station. You can get them at most camp stores. I doubt your mileage will vary that much if you go the SD->ND->MN->IA route, unless you run into heavy winds. If you do run into heavy winds just draft (at about 200 ft) a fast moving semi for 50 miles or so, you will be amazed at the mileage boost. On the WI route I would expect heavy traffic, so that one might vary more.
I did an IBA Saddle Sore 1000 in March of this year. It was easy and fun. I completed it in 18 hours and 20 minutes, and I had one lengthy (45 minutes) stop for a meal. If my life depended on it, I am sure I could do one in 14 or 15 hours. My next endurance ride will be the Bun Burner 1500. I did "a loop" route. My bike is stock except for a Givi windscreen, grip puppies, and an OEM topcase. One caveat: shoot for doing 1,100 miles on your odo. I went 1099 miles according to my odo and my official mileage was 1043 miles. It would suck to come up 10 miles short because of odo inaccuracy....
:cheers:
Discussion Starter #19
:cheers:
That's what I figured. Suck to go 10XX and not get it. 1200 . . .why not?
Good practice for a 1.5k
1 - 19 of 19 Posts
