1 - 3 of 3 Posts
Numb fingers seem to be an issue for me. I'm sure a large part of it is the ninja death grip I have on the bars but I'm convinced that there's still a bit of vibration coming from the engine that I wanted to deal with.
Enter the Rox anti-vibration 2" risers. Puts the bars in a more comfortable position (at least for me) and based on the quick ride I took this evening a lot less vibration.
Install was without any helpers which made it a little awkward at times. In particular to get the bar shims on the risers to stay in place while bolting everything together. A little piece of double sided tape on the inside surface did the trick to keep things from moving as I fitted it all together.
The anti-vibration mounts do give kind of a soft feel to the bars which I guess is to be expected. They seem well constructed and start to finish everything took about 25 minutes.
I ordered them from motorcycleinnovations.ca, delivered in 3 days (good by Canadian standards)
Discussion Starter #2
Forgot to mention that no real issue with cable length. Clutch and brake were fine, throttle needed a little adjustment as the idle rev was ~500 RPM above pre-install.
They are an awesome bit of kit.
I have used Speedy's anti vibration risers for the V-650 for the last 2 years and they are great. Now that I have added a Seat Concepts seat foam and cover I sit higher and I have noticed that I am further away from the bars... now looking at the 2" Rox anti vibration risers.
1 - 3 of 3 Posts
