1 - 3 of 3 Posts
Looking for some ideas on a problem I have notice on my 08 V. When starting it seems a little slow turning over and runs a little rough for the first few seconds. Thinking it may be my battery, I check the voltage and it was 12.23V. Next I checked it running and it was about 14.2V. Then I notice when I increased the RPM's the voltage dropped to 14.0V. Anyone have an guidance on these symptoms?
Those voltage readings are pretty normal, although your battery may be getting weak. Is it the original?... Mileage? Maintenance done?- Spark plugs, valve clearance, throttle body vacuum synch... Is your normal warmed up idle set to 1300 rpm?
1 - 3 of 3 Posts
